Datasheet ADRF6510 (Analog Devices) - 6
Описание30 MHz Dual Programmable Filters and Variable Gain Amplifiers
Страниц / Страница32 / 6 — ADRF6510. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. …
ВерсияB
ADRF6510. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. ESD CAUTION
ADRF6510 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
IC QUADRATURE MODULATOR 32LFCSP. RF IC Programmable Filter, VGA General Purpose 1MHz ~ 30MHz 32-LFCSP-VQ (5x5). RF Misc ICs and Modules...
ADRF6510ACPZ-R7
924 ₽
ADRF6510ACPZ-R7
971 ₽
Рутоника
ADRF6510ACPZ-R7
983 ₽
ADRF6510ACPZ-R7
ADRF6510 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a Supply Voltages, VPS, VPSD 5.25 V stress rating only; functional operation of the product at these ENBL, GNSW, OFDS, LE, CLK, DATA, SDO VPS + 0.6 V or any other conditions above those indicated in the operational INP1, INM1, INP2, INM2 VPS + 0.6 V, section of this specification is not implied. Operation beyond GND − 0.6 V the maximum operating conditions for extended periods may OPP1, OPM1, OPP2, OPM2 VPS + 0.6 V affect product reliability. OFS1, OFS2 VPS + 0.6 V
ESD CAUTION
GAIN VPS + 0.6 V Internal Power Dissipation 1.4 W θJA (Exposed Pad Soldered to Board) 37.4°C/W Maximum Junction Temperature 150°C Operating Temperature Range −40°C to +85°C Storage Temperature Range −65°C to +150°C Lead Temperature (Soldering 60 sec) 300°C Rev. B | Page 6 of 32 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT BUFFERS PROGRAMMABLE FILTERS VARIABLE GAIN AMPLIFIERS (VGAs) OUTPUT BUFFERS/ADC DRIVERS DC OFFSET COMPENSATION LOOP PROGRAMMING THE FILTERS NOISE CHARACTERISTICS DISTORTION CHARACTERISTICS MAXIMIZING THE DYNAMIC RANGE KEY PARAMETERS FOR QUADRATURE-BASED RECEIVERS APPLICATIONS INFORMATION BASIC CONNECTIONS ERROR VECTOR MAGNITUDE (EVM) PERFORMANCE EVM EFFECT OF FILTER BANDWIDTH ON EVM EFFECT OF OUTPUT VOLTAGE LEVELS ON EVM EFFECT OF COFS ON EVM ANTI-ALIASING FILTER EVALUATION BOARD EVALUATION BOARD CONTROL SOFTWARE SCHEMATICS AND ARTWORK EVALUATION BOARD CONFIGURATION OPTIONS USB Section Configuration Options OUTLINE DIMENSIONS ORDERING GUIDE
