Datasheet ADL5243 (Analog Devices) - 7
Описание100 MHz TO 4000 MHz RF/IF Digitally Controlled VGA
Страниц / Страница40 / 7 — Data Sheet. ADL5243. Parameter. Conditions. Min. Typ. Max. Unit
ВерсияB
Data Sheet ADL5243 Parameter Conditions Min Typ Max Unit
21 предложений от 14 поставщиков
Усилитель IC и модуль RF, RF Amplifier IC, 31.5dB Gain, 100MHz to 4GHz, 4.75V to 5.25V, 1W, LFCSP-32
Рутоника
ADL5243ACPZ-R7
612 ₽
ADL5243ACPZ-R7
1 462 ₽
ADL5243ACPZ-R7
ADL5243ACPZ-R7
DSA FREQUENCY = 943 MHz Using the DSAIN and DSAOUT pins, minimum attenuation Insertion Loss −1.6 dB vs. Frequency ±18 MHz ±0.01 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.13 dB Attenuation Range Between maximum and minimum attenuation states 30.9 dB Attenuation Step Error All attenuation states ±0.15 dB Attenuation Absolute Error All attenuation states ±0.28 dB Input Return Loss −16.0 dB Output Return Loss −15.9 dB Input 1 dB Compression Point 30.5 dBm Input Third-Order Intercept ∆f = 1 MHz, POUT = 5 dBm/tone 50.7 dBm DSA FREQUENCY = 1960 MHz Using the DSAIN and DSAOUT pins, minimum attenuation Insertion Loss −2.5 dB vs. Frequency ±30 MHz ±0.04 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.18 dB Attenuation Range Between maximum and minimum attenuation states 30.8 dB Attenuation Step Error All attenuation states ±0.15 dB Attenuation Absolute Error All attenuation states ±0.35 dB Input Return Loss −10.3 dB Output Return Loss −9.6 dB Input 1 dB Compression Point 31.5 dBm Input Third-Order Intercept ∆f = 1 MHz, POUT = 5 dBm/tone 49.6 dBm DSA FREQUENCY = 2140 MHz Using the DSAIN and DSAOUT pins, minimum attenuation Insertion Loss −2.6 dB vs. Frequency ±30 MHz ±0.02 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.19 dB Attenuation Range Between maximum and minimum attenuation states 30.9 dB Attenuation Step Error All attenuation states ±0.13 dB Attenuation Absolute Error All attenuation states ±0.32 dB Input Return Loss −9.8 dB Output Return Loss −9.3 dB Input 1 dB Compression Point 31.5 dBm Input Third-Order Intercept ∆f = 1 MHz, POUT = 5 dBm/tone 49.6 dBm DSA FREQUENCY = 2630 MHz Using the DSAIN and DSAOUT pins, minimum attenuation Insertion Loss −2.8 dB vs. Frequency ±60 MHz ±0.02 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.21 dB Attenuation Range Between maximum and minimum attenuation states 31.2 dB Attenuation Step Error All attenuation states ±0.18 dB Attenuation Absolute Error All attenuation states ±0.24 dB Input Return Loss −10.0 dB Output Return Loss −9.6 dB Input 1 dB Compression Point 31.5 dBm Input Third-Order Intercept ∆f = 1 MHz, POUT = 5 dBm/tone 48.3 dBm Rev. B | Page 7 of 40 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information Basic Layout Connections Amplifier 1 Power Supply Amplifier 1 RF Input Interface Amplifier 1 RF Output Interface Amplifier 2 Power Supply Amplifier 2 RF Input Interface Amplifier 2 RF Output Interface DSA RF Input Interface DSA RF Output Interface DSA SPI Interface SPI Timing SPI Timing Sequence ADL5243 Amplifier 2 Matching ADL5243 Loop Performance Proper Driving Level for the Optimum ACLR Thermal Considerations Soldering Information and Recommended PCB Land Pattern Evaluation Board Outline Dimensions Ordering Guide
