Datasheet ADL5336 (Analog Devices) - 10
ОписаниеCascadable IF VGAs with Programmable RMS Detectors
Страниц / Страница30 / 10 — ADL5336. Data Sheet. –40°C. +25°C. +85°C. 200Ω. 100Ω. re:. (dBm. IP3. …
ВерсияC
ADL5336. Data Sheet. –40°C. +25°C. +85°C. 200Ω. 100Ω. re:. (dBm. IP3. –10. 100. 150. 200. 250. 300. 350. 400. 450. 500. FREQUENCY (MHz)
ADL5336 Data Sheet –40°C +25°C +85°C 200Ω 100Ω re: (dBm IP3 –10 100 150 200 250 300 350 400 450 500 FREQUENCY (MHz)
12 предложений от 11 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
ADL5336ACPZ-R7
708 ₽
Зенер
Россия и страны ТС
ADL5336ACPZ-R7
1 702 ₽
ADL5336ACPZ-R7
ADL5336ACPZ-R7
ADL5336 Data Sheet 40 33 50 40 –40°C –40°C +25°C +25°C 45 35 35 +85°C 28 +85°C 40 30 30 23 ) ) 35 25 25 18 200Ω 30 20 V) 100Ω V) re: B re: B 20 13 (d 25 15 (d (dBm IP3 (dBm IP3 O 20 10 O 15 8 IP3 IP3 O O 15 5 10 3 10 0 5 –2 5 –5 0 –7 0 –10 0 50 100 150 200 250 300 350 400 450 500
013
016
FREQUENCY (MHz) FREQUENCY (MHz)
09550- 09550- Figure 17. OIP3 vs. Frequency over Temperature for VGA1 Figure 20. OIP3 vs. Frequency over Temperature for VGA2
14 7 16 6 GAIN CODE 11 GAIN CODE 00 12 14 4 5 ) ) 12 2 10 3 200Ω ) 100Ω 10 0 ) 8 re: 1 BV re: BV d d B ( 8 –2 B ( (dBm (dBm 6 1d 1d B –1 P B P O 6 –4 O P1d P1d O O 4 –3 4 –6 2 –5 2 –8 GAIN CODE 11 GAIN CODE 00 0 –7 0 –10 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0
020
022
GAIN1 (V) GAIN2 (V)
09550- 09550- Figure 18. OP1dB vs. V Figure 21. OP1dB vs. V GAIN over Gain Code for VGA1 GAIN over Gain Code for VGA2
15 8 16 6 –40°C –40°C +25°C 13 +25°C 6 +85°C 14 +85°C 4 11 4 12 2 ) ) 9 2 200Ω ) 10 100Ω 0 ) 7 0 re: BV re: BV d d 5 –2 8 –2 B ( Bm B ( d 1d (dBm 1d P B ( 3 –4 P B O 6 –4 O 1d P P1d 1 O –6 O 4 –6 –1 –8 2 –8 –3 –10 –5 –12 0 –10 0 50 100 150 200 250 300 350 400 450 500
019
021
09550- 09550- Figure 19. OP1dB vs. Frequency over Temperature for VGA1 Figure 22. OP1dB vs. Frequency over Temperature for VGA2 Rev. C | Page 10 of 30 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT DESCRIPTION GAIN CONTROL INTERFACE INPUT AND OUTPUT IMPEDANCES AGC OPERATION REGISTER MAP AND CODES APPLICATIONS INFORMATION BASIC CONNECTIONS SUPPLY DECOUPLING INPUT SIGNAL PATH OUTPUT SIGNAL PATH DETECTOR OUTPUT AND GAIN PIN COMMON-MODE BYPASSING SERIAL PORT CONNECTIONS MODE AND ENABLE CONNECTIONS ERROR VECTOR MAGNITUDE (EVM) EFFECT OF CAGC ON EVM AGC INSENSITIVITY TO MODULATION TYPE EFFECT OF SETPOINT ON EVM CASCADED VGA/AGC PERFORMANCE EVALUATION BOARD LAYOUT BILL OF MATERIALS (BOM) EVALUATION BOARD CONTROL SOFTWARE OUTLINE DIMENSIONS ORDERING GUIDE
