Datasheet HMC960LP4E (Analog Devices) - 5
ОписаниеDC - 100 MHz Dual Digital Variable Gain Amplifier SMT with Driver
Страниц / Страница20 / 5 — HMC960LP4E. DC - 100 MHz DUAL DigitAL. VAriAbLe gAin AMpLifier with …
HMC960LP4E. DC - 100 MHz DUAL DigitAL. VAriAbLe gAin AMpLifier with DriVer. figure 8. Output ip2 vs
HMC960LP4E DC - 100 MHz DUAL DigitAL VAriAbLe gAin AMpLifier with DriVer figure 8 Output ip2 vs
18 предложений от 18 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ оценочные и демонстрационные наборы
HMC960LP4E
3 166 ₽
131109-HMC960LP4E
11 519 ₽
131109-HMC960LP4E
83 068 ₽
Зенер
Россия и страны ТС
131109-HMC960LP4E
90 504 ₽
HMC960LP4E
v01.1212
DC - 100 MHz DUAL DigitAL VAriAbLe gAin AMpLifier with DriVer figure 8. Output ip2 vs. figure 7. iM2 vs. frequency & gain [4] frequency & gain [4]
-95 110 0 dB 100 10 dB 20 dB -100 30 dB 40 dB ) 90 c ) B m d -105 0 dB B ( 10 dB 2 (d 20 dB 2 IM 80 30 dB 40 dB OIP -110 70 -115 60 10 20 30 40 50 60 70 80 10 20 30 40 50 60 70 80 FREQUENCY (MHz) FREQUENCY (MHz)
figure 9. iM3 vs. frequency and gain, figure 10. iM3 vs. frequency & gain,
T
Standard bias Setting [5][7] High Linearity bias Setting [6][7]
M -40 -40 S Gain Settings 0dB -50 0dB Less Than 30 dB -50 5dB 5dB - Gain Settings 10dB 10dB 15dB 20dB Less Than 30 dB 15dB G -60 20dB -60 25dB 25dB 30dB 30dB ) c c 35dB 35dB IN B B -70 40dB -70 40dB (d (d 3 S 3 Gain Settings IM IM 30 dB or Greater -80 Gain Settings S -80 30 dB or Greater E -90 -90 C -100 -100 10 100 10 100 FREQUENCY (MHz) RO FREQUENCY (MHz) P D
figure 11. Output ip3 vs. frequency & figure 12. Output ip3 vs. frequency &
N
gain, High Linearity bias Setting [6] [7]
A
gain, Standard bias Setting [5] [7]
B 45 45 E 40 40 Greater Than 30 dB S Gain Setting Greater Than 30 dB 35 A 35 Gain Setting ) 30 30 Bm Bm 0dB 0dB (d (d 5dB IF/B 25 5dB 25 10dB IP3 10dB IP3 O 15dB O 15dB 20dB Less Than 30 dB 20dB 20 25dB Gain Setting 20 25dB 30dB 30dB Less Than 30 dB 35dB 35dB 40dB 40dB Gain Setting 15 15 10 10 10 100 10 100 FREQUENCY (MHz) FREQUENCY (MHz) [3] VGA Gain = 0 dB, 2 Vpp differential output [4] 300 mVppd output, load impedance = 400 Ω differential [5] Amplifier bias setting = ‘01’ (Standard Setting) [6] Amplifier bias setting = ‘10’ (High Linearity Setting) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e Anry a alog n D d t evic o p es is la be c liee o ved rd to e b r e sa: H ccur iattte itae M nd reliic a r bl o e. w H a o v wee C ver, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
5
978-250-3343 tel • 978-250-3373 fax • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd P e h r O one n : 7 -li 81 n -3e a 29- t w 470 ww. 0 • O hi rd tetite r on .lic n om license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com Application S Trademarks and registered trademarks are the property of their respective owners. upport: apps@ Aphpitlitcit atei. o co n S m upport: Phone: 1-800-ANALOG-D
