Datasheet HMC680LP4, 680LP4E (Analog Devices) - 5
ОписаниеBiCMOS 5-Bit Digital Variable Gain Amplifier SMT, 30 - 400 MHz
Страниц / Страница8 / 5 — HMC680LP4 / 680LP4E. BiCMOS MMIC 5-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, …
Формат / Размер файлаPDF / 555 Кб
HMC680LP4 / 680LP4E. BiCMOS MMIC 5-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, 30 - 400 MHz. Outline Drawing. Package Information
HMC680LP4 / 680LP4E BiCMOS MMIC 5-BIT DIGITAL VARIABLE GAIN AMPLIFIER, 30 - 400 MHz Outline Drawing Package Information
Усилитель IC и модуль RF, RF Amp Single VGA 400MHz 5.6V 24Pin QFN EP T/R
HMC680LP4E
877 ₽
Элитан
HMC680LP4E
1 657 ₽
HMC680LP4E
HMC680LP4E
Hittite
HMC680LP4 / 680LP4E
v03.0609
12 t m nOtes: s 1. leadframe material: COpper allOY 2. dimensiOns are in inCHes [millimeters] l - 3. lead spaCing tOleranCe is nOn-CUmUlatiVe. 4. pad bUrr lengtH sHall be 0.15mm maXimUm. pad bUrr HeigHt sHall be 0.05mm maXimUm. ita 5. paCKage Warp sHall nOt eXCeed 0.05mm. 6. all grOUnd leads and grOUnd paddle mUst ig be sOldered tO pCb rf grOUnd. 7. refer tO Hittite appliCatiOn nOte fOr sUggested land pattern.
Package Information
s - d r part number package body material lead finish msl rating package marking [3] ie HmC680lp4 low stress injection molded plastic sn/pb solder msl1 [1] H680 XXXX HmC680lp4e roHs-compliant low stress injection molded plastic 100% matte sn msl1 [2] H680 lif XXXX p [1] max peak reflow temperature of 235 °C [2] max peak reflow temperature of 260 °C m [3] 4-digit lot number XXXX in a a le g b ia r a V Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
12 - 5
Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
