Datasheet BC846, BC847, BC848, BC849, BC850 (Fairchild) - 5
ПроизводительFairchild
ОписаниеNPN Epitaxial Silicon Transistor
Страниц / Страница5 / 5 — BC8. TRADEMARKS. 46- BC850. NPN. Epit. axial Silicon T. ransistor. …
Формат / Размер файлаPDF / 151 Кб
BC8. TRADEMARKS. 46- BC850. NPN. Epit. axial Silicon T. ransistor. DISCLAIMER. LIFE SUPPORT POLICY. PRODUCT STATUS DEFINITIONS
BC8 TRADEMARKS 46- BC850 NPN Epit axial Silicon T ransistor DISCLAIMER LIFE SUPPORT POLICY PRODUCT STATUS DEFINITIONS
Bipolar (BJT) Transistor NPN 30 V 100 mA 300MHz 310 mW Surface Mount SOT-23-3
727GS
BC849AMTF
28 ₽
BC849AMTF
Fairchild
BC849AMTF
SUV System
BC849AMTF
The following are registered and unregistered trademarks Fairchild Semiconductor owns or is authorized to use and is not intended to be an exhaustive list of all such trademarks. ACEx™ FACT Quiet Series™ OCX™ SILENT SWITCHER® UltraFET® ActiveArray™ GlobalOptoisolator™ OCXPro™ SMART START™ UniFET™ Bottomless™ GTO™ OPTOLOGIC® SPM™ VCX™
NPN
Build it Now™ HiSeC™ OPTOPLANAR™ Stealth™ Wire™ CoolFET™ I2C™ PACMAN™ SuperFET™ CROSSVOLT™ i-Lo™ POP™ SuperSOT™-3
Epit
DOME™ ImpliedDisconnect™ Power247™ SuperSOT™-6 EcoSPARK™ IntelliMAX™ PowerEdge™ SuperSOT™-8
axial Silicon T
E2CMOS™ ISOPLANAR™ PowerSaver™ SyncFET™ EnSigna™ LittleFET™ PowerTrench® TCM™ FACT™ MICROCOUPLER™ QFET® TinyBoost™ FAST® MicroFET™ QS™ TinyBuck™ FASTr™ MicroPak™ QT Optoelectronics™ TinyPWM™ FPS™ MICROWIRE™ Quiet Series™ TinyPower™ FRFET™ MSX™ RapidConfigure™ TinyLogic® MSXPro™ RapidConnect™ TINYOPTO™
ransistor
Across the board. Around the world.™ µSerDes™ TruTranslation™ The Power Franchise® ScalarPump™ UHC™ Programmable Active Droop™
DISCLAIMER
FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN;NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. THESE SPECIFICATIONS DO NOT EXPAND THE TERMS OF FAIRCHILD’S WORLDWIDE TERMS AND CONDITIONS, SPE- CIFICALLY THE WARRANTY THEREIN, WHICH COVERS THESE PRODUCTS.
LIFE SUPPORT POLICY
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems which, (a) are 2. A critical component is any component of a life support device or system intended for surgical implant into the body, or (b) support or sustain life, or whose failure to perform can be reasonably expected to cause the failure (c) whose failure to perform when properly used in accordance with of the life support device or system, or to affect its safety or effectiveness. instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Definition
Advance Information Formative or In Design This datasheet contains the design specifications for product development. Specifications may change in any manner without notice. Preliminary First Production This datasheet contains preliminary data, and supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice in order to improve design. No Identification Needed Full Production This datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice in order to improve design. Obsolete Not In Production This datasheet contains specifications on a product that has been discontinued by Fairchild semiconductor. The datasheet is printed for reference information only. Rev. I20
5
www.fairchildsemi.com BC846- BC850 Rev. B
