Datasheet BC846, BC847, BC848, BC849, BC550 (Infineon) - 6
ПроизводительInfineon
ОписаниеNPN Silicon AF Transistors
Страниц / Страница19 / 6 — BC846...-BC850... Electrical Characteristics. Parameter. Symbol. Values. …
Формат / Размер файлаPDF / 187 Кб
BC846...-BC850... Electrical Characteristics. Parameter. Symbol. Values. Unit. min. typ. max. AC Characteristics
BC846...-BC850.. Electrical Characteristics Parameter Symbol Values Unit min typ max AC Characteristics
77 предложений от 32 поставщиков
TRANS NPN 65V 0.1A SOT323. Bipolar (BJT) Transistor NPN 65V 100mA 100MHz 200mW Surface Mount SC-70. Transistors - Bipolar (BJT) -...
Рутоника
BC846BW,115
Nexperia
0.97 ₽
BC846BW-7-G
Diodes
TradeElectronics
BC846BW
BC846BW.115
at TA = 25°C, unless otherwise specified
Parameter Symbol Values Unit min. typ. max. AC Characteristics
Transition frequency fT - 250 - MHz IC = 10 mA, VCE = 5 V, f = 100 MHz Collector-base capacitance Ccb - 0.95 - pF VCB = 10 V, f = 1 MHz Emitter-base capacitance Ceb - 9 - VEB = 0.5 V, f = 1 MHz Short-circuit input impedance h11e kΩ IC = 2 mA, VCE = 5 V, f = 1 kHz, hFE-grp.A - 2.7 - IC = 2 mA, VCE = 5 V, f = 1 kHz, hFE-grp.B - 4.5 - IC = 2 mA, VCE = 5 V, f = 1 kHz, hFE-grp.C - 8.7 - Open-circuit reverse voltage transf. ratio h12e 10-4 IC = 2 mA, VCE = 5 V, f = 1 kHz, hFE-grp.A - 1.5 - IC = 2 mA, VCE = 5 V, f = 1 kHz, hFE-grp.B - 2 - IC = 2 mA, VCE = 5 V, f = 1 kHz, hFE-grp.C - 3 - Short-circuit forward current transf. ratio h21e IC = 2 mA, VCE = 5 V, f = 1 kHz, hFE-grp.A - 200 - IC = 2 mA, VCE = 5 V, f = 1 kHz, hFE-grp.B - 330 - IC = 2 mA, VCE = 5 V, f = 1 kHz, hFE-grp.C - 600 - Open-circuit output admittance h µ 22e S IC = 2 mA, VCE = 5 V, f = 1 kHz, hFE-grp.A - 18 - IC = 2 mA, VCE = 5 V, f = 1 kHz, hFE-grp.B - 30 - IC = 2 mA, VCE = 5 V, f = 1 kHz, hFE-grp.C - 60 - Noise figure F - 1.2 4 dB IC = 200 µA, VCE = 5 V, f = 1 kHz, ∆ f = 200 Hz, RS = 2 kΩ, BC849..., BC850... Equivalent noise voltage Vn - - 0.135 µV IC = 200 µA, VCE = 5 V, RS = 2 kΩ, f = 10 ... 50 Hz , BC850... 6 2007-04-20
