Datasheet BC856W, BC857W, BC858W, BC859W, BC860W (Infineon) - 5
ПроизводительInfineon
ОписаниеPNP Silicon AF Transistors SOT-323
Страниц / Страница11 / 5 — BC856W...BC860W. Electrical Characteristics. Parameter. Symbol. Values. …
Формат / Размер файлаPDF / 187 Кб
BC856W...BC860W. Electrical Characteristics. Parameter. Symbol. Values. Unit. min. typ. max. AC characteristics
BC856W...BC860W Electrical Characteristics Parameter Symbol Values Unit min typ max AC characteristics
55 предложений от 31 поставщиков
Биполярный транзистор, универсальный, PNP, 65 В, 100 мА, 200 мВт, SOT-323, Surface Mount
Элрус
BC856BW.115
Nexperia
0.74 ₽
BC856BW/DG/B3115
2.40 ₽
BC856BW,115
Nexperia
от 8.67 ₽
BC856BW
21 ₽
at TA = 25 °C, unless otherwise specified.
Parameter Symbol Values Unit min. typ. max. AC characteristics
Transition frequency fT - 250 - MHz IC = 20 mA, VCE = 5 V, f = 100 MHz Collector-base capacitance Ccb - 3 5 pF VCB = 10 V, f = 1 MHz Emitter-base capacitance Ceb - 10 15 VEB = 0.5 V, f = 1 MHz Short-circuit input impedance h11e kΩ IC = 2 mA, VCE = 5 V, f = 1 kHz hFE-gr.
A
- 2.7 - hFE-gr.
B
- 4.5 - hFE-gr.
C
- 8.7 - Open-circuit reverse voltage transf.ratio h12e 10-4 IC = 2 mA, VCE = 5 V, f = 1 kHz hFE-gr.
A
- 1.5 - hFE-gr.
B
- 2 - hFE-gr.
C
- 3 - Short-circuit forward current transf.ratio h21e - IC = 2 mA, VCE = 5 V, f = 1 kHz hFE-gr.
A
- 200 - hFE-gr.
B
- 330 - hFE-gr.
C
- 600 - Open-circuit output admittance h22e µS IC = 2 mA, VCE = 5 V, f = 1 kHz hFE-gr.
A
- 18 - hFE-gr.
B
- 30 - hFE-gr.
C
- 60 - Noise figure F - - 10 dB IC = 200 µA, VCE = 5 V, RS = 2 kΩ, BC856W f = 1 kHz, ∆ f = 200 Hz BC857W BC858W Noise figure F IC = 200 µA, VCE = 5 V, RS = 2 kΩ, f = 1 kHz, ∆ f = 200 Hz BC859W - 1 4 BC860W - 1 4 Equivalent noise voltage Vn - - 0.11 µV IC = 200 µA, VCE = 5 V, RS = 2 kΩ, BC860W f = 10 ... 50 Hz 4 Jan-28-2005
