Datasheet RV1S9060A (Renesas) - 3
ПроизводительRenesas
ОписаниеHIGH CMR, 15Mbps CMOS OUTPUT, LOW FORWARD-CURRENT(IF) 3.3V/5V OPERATION, 5-PIN with 8mm creepage distance package LSO5 PHOTOCOUPLER
Страниц / Страница14 / 3 — RV1S9060A. 章題. MARKING. EXAMPLE. R. Company. Initial. 9060. Type. *. …
Формат / Размер файлаPDF / 2.1 Мб
RV1S9060A. 章題. MARKING. EXAMPLE. R. Company. Initial. 9060. Type. *. Number. N131. Assembly. Lot. N. No. 1. pin. Mark. 1. 31. Week. Assembled. Year. Assembled. (Last. 1
RV1S9060A 章題 MARKING EXAMPLE R Company Initial 9060 Type * Number N131 Assembly Lot N No 1 pin Mark 1 31 Week Assembled Year Assembled (Last 1
30 предложений от 10 поставщиков
Оптопара, 15 Мбит/с, LSOP, 5 вывод(-ов)
ЧипСити
RV1S9060ACCSP-10YC#KC0
Renesas
52 ₽
Renesas
61 ₽
Зенер
Россия и страны ТС
RV1S9060ACCSP-10YV#KC0
от 105 ₽
Эиком
RV1S9060ACCSP-10YC#SC0
Renesas
от 417 ₽
RV1S9060A 章題 MARKING EXAMPLE R Company Initial 9060 Type * Number N131 Assembly Lot N No. 1 pin Mark 1 31 Week Assembled Year Assembled (Last 1 Digit) Rank Code *Applicable type numbers are listed below. *1) RV1S 9060 ACCSP-10Yx Marking type number. “RV1S” and “ACCSP-10Yx ” are omitted from original type numbe r. ORDERING INFORMATION Part Number Order Number Solder Plating Packing Style Safety Standard Application Specification Approval Part Number*1 RV1S9060ACCSP- RV1S9060ACCSP Pb-Free and Embossed Tape 3 000 Standard products RV1S9060A 10YC -10YC#KC0 Halogen Free pcs/reel (UL, CSA approved) RV1S9060ACCSP- RV1S9060ACCSP (Ni/Pd/Au) Embossed Tape 3 000 UL, CSA, 10YV -10YV#KC0 pcs/reel DIN EN 60747-5-5 approved Notes: *1. For the application of the Safety Standard, fol owing part number should be used. ABSOLUTELY MAXIMUM RATINGS (TA=25°C, unless otherwise specified) Parameter Symbol Ratings Unit Diode Forward Current *1 IF 20 mA Reverse Voltage VR 5 V Detector Supply Voltage VDD 6 V Output Voltage VO 6 V Output Current IO 10 mA Power Dissipation *2 Pc 250 mW Isolation Voltage *3 BV 5 000 Vr.m.s. Operating Ambient Temperature TA -40 to +125 C Storage Temperature Tstg -55 to +150 C Notes: 1. Reduced to 0.93mA/°C at TA=110°C or more 2. Reduced to 5.25mW/°C at TA=85°C or more 3. AC Voltage for 1minite at TA=25°C, RH=60% between input and output. Pins 1-2 shorted together, 3-5 shorted together. R08DS0168EJ0100 Rev.1.00 Page 3 of 13 Jun 4, 2019
