Datasheet RV1S9960A (Renesas) - 3
ПроизводительRenesas
ОписаниеHIGH CMR, 15Mbps CMOS OUTPUT, LOW FORWARD-CURRENT(IF) 3.3V/5V OPERATION, 14.5mm LONG-CREEPAGE 8-PIN LSDIP
Страниц / Страница14 / 3 — RV1S9960A. 章題. MARKING. EXAMPLE. Com. R. pany. Initial. 9960. Type. …
Формат / Размер файлаPDF / 2.0 Мб
RV1S9960A. 章題. MARKING. EXAMPLE. Com. R. pany. Initial. 9960. Type. Number. *. Asse. N131. mbly. Lot. N. 1. 31. No. 1. pin. Mark. Week. Assembled. Year. Assembled. (Last. 1
RV1S9960A 章題 MARKING EXAMPLE Com R pany Initial 9960 Type Number * Asse N131 mbly Lot N 1 31 No 1 pin Mark Week Assembled Year Assembled (Last 1
26 предложений от 9 поставщиков
Оптопара, 15 Мбит/с, LSDIP, 8 вывод(-ов)
ЧипСити
RV1S9960ACCSP-10YV#KC0
Renesas
178 ₽
Renesas
178 ₽
Зенер
Россия и страны ТС
от 354 ₽
Элитан
RV1S9960ACCSP-10YC#SC0
Renesas
847 ₽
RV1S9960A 章題 MARKING EXAMPLE Com R pany Initial 9960 Type Number * Asse N131 mbly Lot N 1 31 No. 1 pin Mark Week Assembled Year Assembled (Last 1 Digit) Rank Code *Applicable type numbers are listed below. *1) RV1S 9960 ACCSP-10Yx Marking type number. “RV1S” and “ACCSP-10Yx” are omitted from original type numbe r. ORDERING INFORMATION Part Number Order Number Solder Plating Packing Style Safety Standard Application Specification Approval Part Number*1 RV1S9960ACCSP- RV1S9960ACCSP Pb-Free and Embossed Tape 1 000 Standard products RV1S9960A 10YC -10YC#KC0 Halogen Free pcs/reel (UL, CSA approved) RV1S9960ACCSP- RV1S9960ACCSP (Ni/Pd/Au) Embossed Tape 1 000 UL, CSA, 10YV -10YV#KC0 pcs/reel DIN EN 60747-5-5 approved Notes: *1. For the application of the Safety Standard, fol owing part number should be used. ABSOLUTELY MAXIMUM RATINGS (TA=25°C, unless otherwise specified) Parameter Symbol Ratings Unit Diode Forward Current IF 20 mA Reverse Voltage VR 5 V Detector Supply Voltage VDD 6 V Output Voltage VO 6 V Output Current IO 10 mA Power Dissipation *1 Pc 250 mW Isolation Voltage *2 BV 7 500 Vr.m.s. Operating Ambient Temperature TA -40 to +110 C Storage Temperature Tstg -55 to +125 C Notes: 1. Reduced to 5.0mW/°C at TA=85°C or more 2. AC Voltage for 1minite at TA=25°C, RH=60% between input and output. Pins 1-4 shorted together, 5-8 shorted together. R08DS0169EJ0100 Rev.1.00 Page 3 of 13 Jun 4, 2019
