Datasheet TLE5x09A16(D) (Infineon) - 27
ПроизводительInfineon
ОписаниеAngle sensors for ultra-precise angular position sensing, AMR-based
Страниц / Страница33 / 27 — TLE5x09A16(D) Analog AMR/GMR Angle Sensor. Package information. …
Версия02_00
TLE5x09A16(D) Analog AMR/GMR Angle Sensor. Package information. PG-TDSO-16. 3.1. Package parameters. Table 15. Parameter. Symbol
TLE5x09A16(D) Analog AMR/GMR Angle Sensor Package information PG-TDSO-16 3.1 Package parameters Table 15 Parameter Symbol
34 предложений от 12 поставщиков
, POSITION&a;CURRENT SENSORS
TLE5109A16E2210XUMA1
Infineon
от 75 ₽
ЧипСити
Infineon
224 ₽
Infineon
311 ₽
Infineon
378 ₽
TLE5x09A16(D) Analog AMR/GMR Angle Sensor Package information 3 Package information
The TLE5x09A16(D) is delivered in a green SMD package with lead-free plating, the same
PG-TDSO-16
is used for the single die and the dual die derivates.
3.1 Package parameters Table 15 Package parameters Parameter Symbol Limit Values Unit Notes min. typ. max.
Thermal Resistance R 130 150 K/W Junction-to-Air1) thJA R 35 K/W Junction-to-Case thJC R 70 K/W Junction-to-Lead thJL Moisture Sensitivity Level MSL 3 260°C Lead Frame Cu Plating Sn 100% > 7 µm 1) According to Jedec JESD51-7
3.2 Package outlines Figure 23 Package dimensions
Data Sheet 27 V 2.0 2018-12 Document Outline Features Functional Safety Product Validation Potential Applications Description Table of Contents 1 Functional description 1.1 General 1.2 Pin configuration 1.3 Pin description 1.4 Block diagram 1.5 Dual die angle output 2 Specification 2.1 Application circuit 2.2 Absolute maximum ratings 2.3 Sensor specification 2.3.1 Operating range 2.3.2 Electrical parameters 2.3.3 Output parameters 2.4 Error diagnosis 2.5 Angle performance 2.6 Electrostatic discharge protection 2.7 Electro magnetic compatibility (EMC) 3 Package information 3.1 Package parameters 3.2 Package outlines 3.3 Footprint 3.4 Packing 3.5 Marking 4 Revision history
