Datasheet ADXL1003 (Analog Devices) - 8
ОписаниеLow Noise, Wide Bandwidth, MEMS Accelerometer
Страниц / Страница14 / 8 — ADXL1003. Data Sheet. 600. REFERENCE. 500. XOUT DELTA. OVERRANGE. ) (g. …
Формат / Размер файлаPDF / 518 Кб
ADXL1003. Data Sheet. 600. REFERENCE. 500. XOUT DELTA. OVERRANGE. ) (g. 400. XOUT. 300. RAT. LTAG. 200. ACCE. STANDBY. UT P. 100. –100
ADXL1003 Data Sheet 600 REFERENCE 500 XOUT DELTA OVERRANGE ) (g 400 XOUT 300 RAT LTAG 200 ACCE STANDBY UT P 100 –100
21 предложений от 10 поставщиков
, Accelerometer Single ±200g 5V 9.2mV/g to 10.8mV/g 32-Pin LFCSP EP T/R
ADXL1003BCPZ-RL7
1 996 ₽
727GS
ADXL1003BCPZ-RL7
4 243 ₽
ADXL1003BCPZ
от 10 126 ₽
Элитан
ADXL1003BCPZ
11 150 ₽
ADXL1003 Data Sheet 6 600 12 REFERENCE 5 500 XOUT DELTA 10 OVERRANGE 4 ) (g 400 8 N ) 3 IO ) (V XOUT V E 300 6 ( RAT T E 2 U L P LTAG T 200 4 VO OU 1 ACCE STANDBY UT P 100 2 0 IN 0 0 –1 –2 –100 –2 0 5 10 15 20 25 30 35 40
016
13.0 13.5 14.0 14.5 15.0 15.5 16.0 16.5 17.0 17.5 18.0
18 0 96- 6-
TIME (µs)
165
TIME (ms)
659 1 Figure 16. XOUT Output Recovery from Standby Mode to Measure Mode Figure 18. Response to Overload Condition, XOUT Delta is Difference from Midscale Voltage
204 z) 200.5 H (k 203 200.0 0V (kHz) 202 Y 199.5 = 5. C N DD 201 E U 199.0 , V Q E CY 200 R N 198.5 F UE K 199 Q C 198.0 O RE F 198 CL 197.5 CK AL O 197 L RN 197.0 E C T 196 IN 196.5 RNAL 195 E T 196.0 IN 194
7
–50 0 50 100 150
01
195.5
6-
3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4 4.6 4.8 5.0 5.2
19
TEMPERATURE (°C)
59 0 16
SUPPLY VOLTAGE (V)
16596- Figure 17. Internal Clock Frequency vs. Temperature at 5.0 V Supply Voltage (VDD) Figure 19. Internal Clock Frequency vs. Supply Voltage at 25°C Rev. 0 | Page 8 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE RECOMMENDED SOLDERING PROFILE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL DEVICE OPERATION OPERATING MODES Measure Mode Standby Mode BANDWIDTH APPLICATIONS INFORMATION APPLICATION CIRCUIT ON DEMAND SELF TEST RATIOMETRIC OUTPUT VOLTAGE INTERFACING ANALOG OUTPUT BELOW 10 kHz INTERFACING ANALOG OUTPUT BEYOND 10 kHz OVERRANGE MECHANICAL CONSIDERATIONS FOR MOUNTING LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
