Datasheet ADXL375 (Analog Devices) - 10
Описание3-Axis, ±200 g Digital MEMS Accelerometer
Страниц / Страница10 / 10 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/18612
Формат / Размер файлаPDF / 174 Кб
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/18612
57 предложений от 17 поставщиков
LGA14;Акселерометр 3-х осевой ±200g электропитание 2.5В/3.3В 14-Pin LGA лента на катушке
Элрус
ADXL375BCCZ-RL7
от 527 ₽
ICdarom.ru
ADXL375BCCZ-RL7
от 537 ₽
DIP8.RU
Россия и страны ТС
ADXL375BCCZ-RL7
от 607 ₽
727GS
ADXL375BCCZ-RL7
1 813 ₽
4. VERIFICATION 4.1 Product assurance requirements. The manufacturer is responsible for performing all inspection and test requirements as indicated in their internal documentation. Such procedures should include proper handling of electrostatic sensitive devices, classification, packaging, and labeling of moisture sensitive devices, as applicable. 5. PREPARATION FOR DELIVERY 5.1 Packaging. Preservation, packaging, labeling, and marking shall be in accordance with the manufacturer’s standard commercial practices for electrostatic discharge sensitive devices. 6. NOTES 6.1 ESDS. Devices are electrostatic discharge sensitive and are classified as ESDS class 1 minimum. 6.2 Configuration control. The data contained herein is based on the salient characteristics of the device manufacturer’s data book. The device manufacturer reserves the right to make changes without notice. This drawing will be modified as changes are provided. 6.3 Suggested source(s) of supply. Identification of the suggested source(s) of supply herein is not to be construed as a guarantee of present or continued availability as a source of supply for the item. DLA Land and Maritime maintains an online database of all current sources of supply at https://landandmaritimeapps.dla.mil/programs/smcr/default.aspx Vendor item drawing Device Order Quantity Vendor part number administrative control manufacturer number 1/ CAGE code Tray = 490 ADXL375SCCZ-EP V62/18612-01XE 24355 RL7 quantity = 1500 ADXL375SCCZ-EP -RL7 1/ The vendor item drawing establishes an administrative control number for identifying the item on the engineering documentation. CAGE code Source of supply 24355 Analog Devices 1 Technology Way P.O. Box 9106 Norwood, MA 02062-9106
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/18612
REV PAGE 10 Document Outline DESCRIPTION REV REV PMIC N/A TITLE SIZE A V62/18612 REV
