Datasheet RFP30N06LE, RF1S30N06LESM (Fairchild) - 2
ПроизводительFairchild
Описание30A, 60V, ESD Rated, 0.047 Ohm, Logic Level N-Channel Power MOSFETs
Страниц / Страница8 / 2 — RFP30N06LE, RF1S30N06LESM. Absolute Maximum Ratings. UNITS. Electrical …
Формат / Размер файлаPDF / 194 Кб
RFP30N06LE, RF1S30N06LESM. Absolute Maximum Ratings. UNITS. Electrical Specifications. PARAMETER. SYMBOL. TEST CONDITIONS. MIN. TYP. MAX
RFP30N06LE, RF1S30N06LESM Absolute Maximum Ratings UNITS Electrical Specifications PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX
14 предложений от 11 поставщиков
N-Channel 60 V 30A (Ta) 96W (Tc) Through Hole TO-220-3
727GS
RFP30N06LE
от 35 ₽
RFP30N06LE
303 ₽
RFP30N06LE_NL
Fairchild
SUV System
RFP30N06LE
TA = 25oC, Unless Otherwise Specified
RFP30N06LE, RF1S30N06LESM UNITS
Drain to Source Voltage (Note 1) . VDSS 60 V Drain to Gate Voltage (RGS = 20kΩ) (Note 1) . VDGR 60 V Gate to Source Voltage . VGS +10, -8 V Continuous Drain Current . .ID 30 A Pulsed Drain Current (Note 3) . IDM Refer to Peak Current Curve Pulsed Avalanche Rating . EAS Refer to UIS Curve Power Dissipation . PD 96 W Derate Above 25oC . 0.645 W/oC Electrostatic Discharge Rating, MIL-STD-883, Category B(2). .ESD 2 kV Operating and Storage Temperature . TJ, TSTG -55 to 175 oC Maximum Temperature for Soldering Leads at 0.063in (1.6mm) from Case for 10s. T o L 300 C Package Body for 10s, See Techbrief 334. T o pkg 260 C CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. TJ = 25oC to 150oC.
TC = 25oC, Unless Otherwise Specified
PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNITS
Drain to Source Breakdown Voltage BVDSS ID = 250µA, VGS = 0V, Figure 11 60 - - V Gate to Threshold Voltage VGS(TH) VGS = VDS, ID = 250µA, Figure 10 1 - 2 V Zero Gate Voltage Drain Current IDSS VDS = Rated BVDSS, VGS = 0 - - 25 µA VDS = 0.8 x Rated BVDSS, VGS = 0, TC = 150oC - - 250 µA Gate to Source Leakage Current IGSS VGS = +10, -8V - - ±10 µA Drain to Source On Resistance (Note 2) rDS(ON) ID = 30A, VGS = 5V, Figure 9 - - 0.047 Ω Turn-On Time tON VDD = 30V, ID = 30A, RL = 1Ω, VGS = 5V, - - 140 ns RGS = 2.5Ω, Turn-On Delay Time td(ON) - 11 - ns Figures 13, 16, 17 Rise Time tr - 88 - ns Turn-Off Delay Time td(OFF) - 30 - ns Fall Time tf - 40 - ns Turn-Off Time tOFF - - 100 ns Total Gate Charge Qg(TOT) VGS = 0V to 10V VDD = 48V, - 51 62 nC ID = 30A, Gate Charge at 5V Qg(5) VGS = 0V to 5V - 28 34 nC RL = 1.6Ω Threshold Gate Charge Qg(TH) VGS = 0V to 1V Figures 18, 19 - 1.8 2.6 nC Input Capacitance CISS VDS = 25V, VGS = 0V, - 1350 - pF f = 1MHz Output Capacitance COSS - 290 - pF Figure 12 Reverse Transfer Capacitance CRSS - 85 - pF Thermal Resistance Junction to Case RθJC - - 1.55 oC/W Thermal Resistance Junction to Ambient RθJA - - 80 oC/W
Source to Drain Diode Specifications PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNITS
Source to Drain Diode Voltage (Note 2) VSD ISD = 30A - - 1.5 V Diode Reverse Recovery Time trr ISD = 30A, dISD/dt = 100A/µs - - 125 ns NOTES: 2. Pulse Test: Pulse Width ≤ 300ms, Duty Cycle ≤ 2%. 3. Repetitive Rating: Pulse Width limited by max junction temperature. See Transient Thermal Impedance Curve (Figure 3) and Peak Current Capability Curve (Figure 5). ©2004 Fairchild Semiconductor Corporation RFP30N06LE, RF1S30N06LESM Rev. B1
