Datasheet BAT54TW, BAT54ADW, BAT54CDW, BAT54SDW, BAT54BRW (Diodes) - 2
| Производитель | Diodes |
| Описание | Surface Mount Schottky Barrier Diode Arrays |
| Страниц / Страница | 4 / 2 — BAT54TW /ADW / CDW /SDW /BRW. Maximum Ratings. Characteristic. Symbol. … |
| Формат / Размер файла | PDF / 310 Кб |
BAT54TW /ADW / CDW /SDW /BRW. Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal Characteristics
54 предложений от 27 поставщиков Диод: импульсный Шоттки; SMD; 30В; 0,2А; 5нс; SOT363; бобина,лента |
| BAT54BRW_R1_00001 PanJit | от 2.09 ₽ | |
| BAT54BRW Jiangsu Changjing | 2.23 ₽ | |
| BAT54BRW-7-F Diodes | от 55 ₽ | |
| BAT54BRW
| по запросу | |
BAT54TW /ADW / CDW /SDW /BRW Maximum Ratings
(@TA = +25°C, unless otherwise specified.)
Characteristic Symbol Value Unit
Peak Repetitive Reverse Voltage VRRM Working Peak Reverse Voltage VRWM 30 V DC Blocking Voltage VR Forward Continuous Current (Note 5) IF 200 mA Repetitive Peak Forward Current (Note 5) IFRM 300 mA Forward Surge Current (Note 5) @ t < 1.0s IFSM 600 mA
Thermal Characteristics Characteristic Symbol Value Unit
Power Dissipation (Note 5) PD 200 mW Thermal Resistance, Junction to Ambient Air (Note 5) RJA 625 °C/W Operating and Storage Temperature Range TJ, TSTG -65 to +125 °C
Electrical Characteristics
Characteristic Symbol Min Typ Max Unit Test Condition
Reverse Breakdown Voltage (Note 6) V(BR)R 30 V IR = 100µA 240 IF = 0.1mA 320 I F = 1mA Forward Voltage (Note 6) 400 mV I V F = 10mA F 500 IF = 30mA 1,000 IF = 100mA Reverse Leakage Current (Note 6) IR 2.0 µA VR = 25V Total Capacitance CT 10 pF VR = 1.0V, f = 1.0MHz I Reverse Recovery Time t F = 10mA through IR = 10mA rr 5.0 ns to IR = 1.0mA, RL = 100Ω Notes: 5. Device mounted on FR-4 PCB, 1 inch x 0.85 inch x 0.062 inch; pad layout, which can be found on our website at http://www.diodes.com/package-outlines.html. 6. Short duration pulse test used to minimize self-heating effect. 1 ) 100 A( TNER 10 R 0.1 U C D R A 1 W R O 0.01 F S U 0.1 O E N A T 0.001 N 0.01 A T S NI ,I F 0.001 0.00010 0.2 0.4 0.6 0.8 1.0 0 5 10 15 20 25 30 V , INSTANTANEOUS FORWARD VOLTAGE (V) V , INSTANTANEOUS REVERSE VOLTAGE (V) R F Fig. 1 Typical Forward Characteristics Fig. 2 Typical Reverse Characteristics BAT54TW /ADW /CDW /SDW /BRW 2 of 4 June 2016 Document number: DS30152 Rev. 17 - 2
www.diodes.com
© Diodes Incorporated
