Линейка продуктов KEEN SIDE
Datasheet IS2083 (Microchip) - 11
ПроизводительMicrochip
ОписаниеBluetooth Stereo Audio SoC
Страниц / Страница65 / 11 — IS2083. Device Overview. Figure 2-2.  IS2083BM and IS2083BM-2L2 Ball …
Формат / Размер файлаPDF / 2.9 Мб
IS2083. Device Overview. Figure 2-2.  IS2083BM and IS2083BM-2L2 Ball Diagram. Note: . 2.2
IS2083 Device Overview Figure 2-2.  IS2083BM and IS2083BM-2L2 Ball Diagram Note:  2.2
24 предложений от 11 поставщиков
, BLUETOOTH 5.0 AUDIO SOC / Bluetooth Bluetooth v5.0 Transceiver Module 2.4GHz Antenna Not Included Surface Mount
IS2083BM-232-TRAY
591 ₽
IS2083BM-232-TRAY
620 ₽
IS2083BM-232-TRAY
от 1 120 ₽
Элитан
IS2083BM-232-TRAY
1 151 ₽
A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 MIC_N2 AOHPL AOHPM VDDA_CODEC AOHPR PA1OP GND RTX VCC_BTPA VCC_RF B1 B2 B3 B4 B5 B6 B7 B8 B9 B10 MIC_P2 SCLK1 RFS1 VCOM P1_3/ P1_2/ VCC_PA1 P0_1 P2_3 XO_P TCK_CPU/ TDI_CPU/ SDA SCL C1 C2 C3 C6 C8 C9 C10 MIC_N1 DT1 DR1 NC VDD_IO P1_6/ XO_N PWM1 D1 D2 D3 D8 D9 D10 MIC_P1 MCLK1 VDD_IO RST_N P0_5 ULPC_VSUS E1 E2 E3 E5 E6 E8 E9 E10 MICBIAS DMIC_CLK DMIC1_L GND P0_7 P0_2 P2_7 VBG F1 F2 F3 F5 F6 F8 F9 F10 ADAP_IN DMIC1_R AIR GND GND P0_0/ P0_3 RFLDO_O UART_TX_IND G1 G2 G3 G8 G9 G10 BAT_IN P3_2 AIL USB_1V2/ P3_5 PMIC_IN VDD_CORE H1 H2 H3 H5 H8 H9 H10 SARVDD P0_6 P2_6 VDD_CORE AVDD_USB/ P3_7/ CLDO_O/ VDD_IO_10 UART_CTS VDD_PLL J1 J2 J3 J4 J5 J6 J7 J8 J9 J10 SYS_POWER P8_6/ P8_5/ SK1 SK2 VDD_CORE P3_4/ LED1 LED2 USB_DP UART_RXD UART_TXD UART_RTS K1 K2 K3 K4 K5 K6 K7 K8 K9 K10 BK1_VDDC BK1_LX1 BK1_VOUT MFB LDO31_VO LDO31_VIN BK2_VOUT BK2_LX BK2_VDD USB_DM
Note: 
The IS2083BM-2L2 does not support an analog output from the internal DAC. The AOHPR, AOHPM and AOHPL are affected pins.
2.2 IS2083BM Device Ball Description Table 2-2. IS2083BM and IS2083BM-2L2 Ball Description IS2083BM Ball IS2083BM-2L2 Ball Ball Name Ball Description Number Number Type
A1 A1 MIC_N2 I MIC2 mono differential analog negative input A2 - AOHPL(1) O Left channel, analog headphone output A3 - AOHPM(1) O Headphone common mode output/sense input © 2019 Microchip Technology Inc.
Datasheet
DS70005403B-page 11 Document Outline Introduction Features Table of Contents 1. Quick References 1.1. Reference Documentation 1.2. Acronyms/Abbreviations 2. Device Overview 2.1. IS2083BM Device Ball Diagram 2.2. IS2083BM Device Ball Description 3. Audio Subsystem 3.1. Digital Signal Processor 3.2. Codec 3.2.1. Audio Performance 3.3. Auxiliary Port 3.4. Microphone Inputs 3.5. Analog Speaker Output 4. Bluetooth Transceiver 4.1. Transmitter 4.2. Receiver 4.3. Synthesizer 4.4. Modulator-Demodulator 4.5. Adaptive Frequency Hopping 5. Microcontroller 5.1. Memory 5.2. Clock 6. Power Management Unit 6.1. Device Operation 6.2. Power Supply 6.3. Adapter Input 6.4. Buck1 (BK1) Switching Regulator 6.5. Buck2 (BK2) Switching Regulator 6.6. Low-Droput Regulator 6.7. Battery Charging 6.7.1. Battery Charger Detection 6.8. SAR ADC 6.9. LED Driver 7. Application Information 7.1. Power On/Off Sequence 7.2. Reset 7.3. Programming and Debugging 7.3.1. Test Mode 7.3.2. Flash Memory and SQI Controller 7.3.2.1. SQI Controller 7.3.3. 2-wire Interface 7.3.3.1. Serial Program Clock 7.3.3.2. Serial Program Data 7.3.4. Enabling Programming Interface 7.3.5. On-chip Instrumentation 7.3.5.1. Enabling OCI Functionality 7.3.5.2. Entering Debug Mode 7.3.5.3. Reading the Debug Status 7.3.5.4. Reading the Program Counter 7.3.5.5. Stopping Program Execution (Entering Debug Mode) 7.3.5.6. Starting Program Execution (Exiting Debug Mode) 7.3.5.7. User Single Step Mode 7.3.5.8. OCI Single Step Mode 7.3.5.9. Setting Software Breakpoints 7.3.5.10. Simple and Complex Debug Triggers 7.3.5.11. Reading and Writing Memory/SFR Registers 7.3.5.12. Trace Buffer 7.3.5.13. Instruction Trace 7.4. General Purpose I/O Pins 7.5. I2S Mode Application 7.6. Host MCU Interface 8. Electrical Specifications 8.1. Timing Specifications 9. Package Information 10. Ordering Information 11. Document Revision History The Microchip Website Product Change Notification Service Customer Support Microchip Devices Code Protection Feature Legal Notice Trademarks Quality Management System Worldwide Sales and Service
