Datasheet NLM0011 / NLM0010 NFC-PWM Series (Infineon) - 7
ПроизводительInfineon
ОписаниеNFC Wireless Configuration IC with PWM Output
Страниц / Страница35 / 7 — NLM0011/ NLM0010 " NFC-PWM Series ". NFC Wireless Configuration …
Версия02_00
Формат / Размер файлаPDF / 511 Кб
NLM0011/ NLM0010 " NFC-PWM Series ". NFC Wireless Configuration IC with PWM Output. 3 Application Overview
NLM0011/ NLM0010 " NFC-PWM Series " NFC Wireless Configuration IC with PWM Output 3 Application Overview
35 предложений от 11 поставщиков
RFID, NFC W/PWM, 13.56MHZ, SOT-23-5
NLM0011XTSA1
Infineon
42 ₽
ЧипСити
NLM0011XTSA1
Infineon
53 ₽
Эиком
NLM0011XTSA1
Infineon
от 67 ₽
Элитан
NLM0011XTSA1
Infineon
127 ₽
Датчики давления китайских производителей: высокое качество и доступность
NLM0011/ NLM0010 " NFC-PWM Series " NFC Wireless Configuration IC with PWM Output 3 Application Overview Vout,diode,drop N I P out L NS p Output Input Lp,lk CEMI
Optional VCC regulator
RZCD,1 NA CVCC RZCD,2 RHV
HV VCC ZCD GD CS
XDPL8105 RCS
DIM GND Dual Mode NFC Configuration LA R Antenna LB
NLM0011
PWM Set the rated LED current C2 GND VCC VCC power supply C1 Ground
Figure 2 Application example
The parameters of the PWM output are period and duty cycle. Both have to be configured during NFC configuration. The values of the configuration parameters have to be calculated according to the requirements of the application. Using an external R/C circuitry with a given time constant, the duty cycle and period of the PWM can be calculated to generate any value between minimum and maximum output voltage of the digital PWM output driver. The calculated parameters including the aging function are written into the NVM of the NLM0011/NLM0010 during NFC configuration. That can only be done if the NLM0011/NLM0010 is powered off. The NLM0011/ NLM0010 will harvest the energy from the electromagnetic NFC field and supply itself in that case. Datasheet 7 2.0 2019-05-31 Document Outline Features Description Table of contents 1 General 2 Feature Overview 3 Application Overview 4 Pin Description 5 Functional Description 6 Memory Organization 7 Application and User Memory Access Control 8 NLM0011/NLM0010 EEPROM Shipment Content (Infineon to Customer) 9 Constant Lumen Output (CLO) and Operating Time Counting (OTC) 10 PWM Overview 11 NLM0011/ NLM0010 Command Set 12 NLM0011/ NLM0010 Electrical Characteristics 13 Package Outline Revision history Disclaimer
