Datasheet 235 EDLC-HVR ENYCAP (Vishay) - 2
ПроизводительVishay
ОписаниеRuggedized Electrical Double Layer Energy Storage Capacitors Up to 3 V Operating Voltage
Страниц / Страница6 / 2 — 235 EDLC-HVR ENYCAP™. DIMENSIONS. AND AVAILABLE FORMS. Form CA / TRAY:. …
Формат / Размер файлаPDF / 133 Кб
235 EDLC-HVR ENYCAP™. DIMENSIONS. AND AVAILABLE FORMS. Form CA / TRAY:. Form TFA. Table 1. MASS, AND PACKAGING QUANTITIES
235 EDLC-HVR ENYCAP™ DIMENSIONS AND AVAILABLE FORMS Form CA / TRAY: Form TFA Table 1 MASS, AND PACKAGING QUANTITIES
28 предложений от 10 поставщиков
Суперконденсатор, AEC-Q200, 25 Ф, 3 В, Радиальные Выводы, ENYCAP 235 EDLC-HVR Series, +50%, -20%
MAL223551006E3
211 ₽
MAL223551006E3
306 ₽
Элитан
MAL223551006E3
409 ₽
MAL223551006E3
www.vishay.com Vishay BCcomponents
DIMENSIONS
in millimeters
AND AVAILABLE FORMS
L Ø d F Ø D 5 15 min. min. Fig. 1 -
Form CA / TRAY:
Long leads Fig. 2 -
Form TFA
: Taped in box (ammopack)
Table 1 DIMENSIONS
in millimeters,
MASS, AND PACKAGING QUANTITIES NOMINAL CASE SIZE MASS PACKAGING QUANTITIES CASE CODE Ø d Ø D Ø D x L max. Lmax. F (g) FORM CA FORM TFA FORM TRAY
10 x 20 16 0.6 10.5 22 5.0 ± 0.5  2.2 500 800 - 10 x 25 16L 0.6 10.5 27 5.0 ± 0.5  3.0 500 800 - 10 x 30 16LL 0.8 10.5 32 5.0 ± 0.5  3.5 500 800 - 12.5 x 20 17 0.6 13.0 22 5.0 ± 0.5  4.0 500 500 - 12.5 x 25 18 0.6 13.0 27 5.0 ± 0.5  5.0 250 500 - 12.5 x 30 18L 0.8 13.0 33.5 5.0 ± 0.5  5.5 250 500 - 12.5 x 40 18LL 0.8 13.0 42.5 5.0 ± 0.5  7.0 250 - - 16 x 20 19a 0.8 16.5 22 7.5 ± 0.5  6.0 250 250 200 16 x 25 19 0.8 16.5 27 7.5 ± 0.5  8.0 250 250 200 18 x 20 1820 0.8 18.5 22 7.5 ± 0.5  7.0 100 250 200 18 x 25 1825 0.8 18.5 27 7.5 ± 0.5  10.0 100 250 200 16 x 31 20 0.8 16.5 33.5 7.5 ± 0.5  9.0 100 250 200 18 x 31 1831 0.8 18.5 33.5 7.5 ± 0.5  12.5 100 250 200 18 x 35 22 0.8 18.5 37.5 7.5 ± 0.5  14.5 100 250 200 18 x 40 1840 0.8 18.5 42.5 7.5 ± 0.5  16.5 100 - 150
ORDERING EXAMPLE ELECTRICAL DATA
Capacitor series 235 EDLC-HVR
SYMBOL DESCRIPTION
40 F / 3.0 V CR Rated capacitance, tolerance -20 % / +50 % Nominal case size: Ø 18 mm x 31 mm; Form TRAY IP Max. peak current Ordering code: MAL223591001E3 IL Max. leakage current after 0.5 h / 72 h at UR
Note
• Unless otherwise specified, all electrical values in Table 2 apply at Tamb = 20 °C, P = 86 kPa to 106 kPa and RH = 45 % to 75 % Revision: 08-Oct-2019
2
Document Number: 28455 For technical questions, contact: energystorage@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
