Datasheet AP22913 (Diodes) - 3
ПроизводительDiodes
ОписаниеSingle Slew Rate Controlled Load Switch
Страниц / Страница17 / 3 — AP22913. Absolute Maximum Ratings. Symbol. Parameter. Ratings. Unit. …
Формат / Размер файлаPDF / 1.6 Мб
AP22913. Absolute Maximum Ratings. Symbol. Parameter. Ratings. Unit. Recommended Operating Conditions. Min. Max. www.diodes.com
AP22913 Absolute Maximum Ratings Symbol Parameter Ratings Unit Recommended Operating Conditions Min Max www.diodes.com
34 предложений от 11 поставщиков
IC: power switch; high-side,USB switch; 2А; Ch: 1; P-Channel; SMD
AP22913CN4-7
Diodes
от 3.44 ₽
AP22913CN4-7
Diodes
от 21 ₽
Эиком
AP22913CN4-7
Diodes
от 23 ₽
AP22913CN4-7
Diodes
36 ₽
(@TA = +25°C, unless otherwise specified.)
ESD HBM Human Body Model ESD Protection 6 kV ESD CDM Charged Device Model ESD Protection 2 kV VIN Input Voltage -0.3 to 6 V VOUT Output Voltage -0.3 to 6 V VON ON Voltage -0.3 to 6 V ILOAD Maximum Continuous Load Current 2 A
T
ILOAD Maximum Pulse Load Current, Pulse <300µs, 2% Duty Cycle 2.5 A
C
TJ Maximum Junction Temperature +125 °C
U
T
D
ST Storage Temperature Range -65 to +150 °C
O
X1-WLB0909-4 930 mW P
R
D Power Dissipation SOT26 760 mW
P
X1-WLB0909-4 136 °C/W RθJA Thermal Resistance, Junction to Ambient (Note 4)
W
SOT26 165 °C/W
E
X1-WLB0909-4 31 °C/W
N
RθJC Thermal Resistance, Junction to Case (Note 5) SOT26 30 °C/W Notes: 4. The JEDEC high-K (2s2p) board used to derive this data was a 3 inch x 3 inch, multilayer board with 1oz internal power and ground planes with 2oz copper traces on top and bottom of the board. 5. Thermal resistance from junction to case. Caution: Stresses greater than the 'Absolute Maximum Ratings' specified above, can cause permanent damage to the device. These are stress ratings only; functional operation of the device at these or any other conditions exceeding those indicated in this specification is not implied. Device reliability can be affected by exposure to absolute maximum rating conditions for extended periods of time.
Symbol Parameter Min Max Unit
VIN Input Voltage 1.4 5.5 V VON ON Voltage Range 0 5.5 V VOUT Output Voltage 1.4 5.5 V IOUT Output Current 0 2.0 A VIH ON High-Level Input Voltage 1.1 5.5 V ON Low-Level Input VIN = 3.6V to 5.5V 0 0.6 V VIL Voltage VIN = 1.4V to 3.6V 0 0.4 V TA Operating Ambient Temperature -40 +85 °C AP22913 3 of 17 March 2019 Document number: DS41203 Rev. 3 - 2
www.diodes.com
© Diodes Incorporated
