Datasheet MIC4609 (Microchip) - 6
ПроизводительMicrochip
Описание600V 3-Phase MOSFET/IGBT Driver
Страниц / Страница36 / 6 — MIC4609. AC/DC ELECTRICAL CHARACTERISTICS (Note 1, 2). Electrical …
Формат / Размер файлаPDF / 782 Кб
MIC4609. AC/DC ELECTRICAL CHARACTERISTICS (Note 1, 2). Electrical Specifications:. Bold. Parameter. Symbol. Min. Typ. Max. Units
MIC4609 AC/DC ELECTRICAL CHARACTERISTICS (Note 1, 2) Electrical Specifications: Bold Parameter Symbol Min Typ Max Units
IC GATE DRVR HALF-BRIDGE 28SOIC. Half-Bridge Gate Driver IC Non-Inverting 28-SOIC. PMIC - Gate Drivers
ЧипСити
MIC4609YWM-TR
151 ₽
Hi-Tech Circuit Group
MIC4609YWM-TR
MIC4609YWM-TR
MIC4609YWM-TR
link to page 6 link to page 6 link to page 6
Unless otherwise indicated, VDD = VxHB = 20V, VEN = 5V, VSS = VxHS = 0V; No load on xLO or xHO, TA = +25°C.
Bold
values indicate –40°C TJ +125°C.
Parameter Symbol Min. Typ. Max. Units Conditions Supply Current
VDD Quiescent Current IDD — 150
250
µA xLI = xHI = 0V EN = 0V with HS = floating VDD Shutdown Current IDDSH — 0.1
10
µA or ground VDD Operating Current IDDO — 240
350
µA f = 20 kHz xLI = xHI = 0V or Total xHB Quiescent Current IxHB — 81
180
µA xLI = 0V and xHI = 5V Total xHB Operating Current IxHBO — 600
1500
µA f = 20 kHz High-Side Leakage Current ILxHB — 1
10
µA VxHB = VxHS = 600V
Input (TTL: xLI, xHI, EN)
Low-Level Input Voltage VIL — —
0.8
V High-Level Input Voltage VIH
2.2
— — V Input Voltage Hysteresis VHYS — 0.2 — V Input Pull-Down Resistance RI
100
370
500
k For xLI and xHI only
(Note 3 ) Undervoltage Protection
VDD Falling Threshold VDDR
7
8
9
V — VDD Threshold Hysteresis VDDH — 0.5 — V — xHB Falling Threshold VxHBR
7
8
9
V — xHB Threshold Hysteresis VxHBH — 0.5 — V —
Note 1:
Specification for packaged product only.
2:
The x in the suffix of a pin name designates any of the three phases, e.g., xHS refers to either AHS, BHS or CHS.
3:
Enable resistance is typical only and is not production tested. DS20005531C-page 6  2016-2019 Microchip Technology Inc. Document Outline 600V 3-Phase MOSFET/IGBT Driver Features Typical Applications General Description Package Type Functional Block Diagram MIC4609 – Top Level Circuit Functional Block Diagram MIC4609 – Phase x Drive Circuit Typical Application Circuit MIC4609 – 300V, 3-Phase Motor Driver 1.0 Electrical Characteristics Absolute Maximum Ratings Operating Ratings AC/DC Electrical Characteristics Temperature Characteristics 2.0 Typical Performance Curves FIGURE 2-1: VDD Quiescent Current vs. VDD Voltage. FIGURE 2-2: VDD Quiescent Current vs. Temperature. FIGURE 2-3: VHB Quiescent Current vs. VHB Voltage. FIGURE 2-4: VHB Quiescent Current vs. Temperature. FIGURE 2-5: VDD+HB Shutdown Current vs. Voltage. FIGURE 2-6: VDD+HB Shutdown Current vs. Temperature. FIGURE 2-7: VDD+HB Shutdown Current vs. Voltage. FIGURE 2-8: VDD+HB Shutdown Current vs. Temperature. FIGURE 2-9: VDD Operating Current vs. Frequency. FIGURE 2-10: VHB Operating Current vs. Frequency – One Phase. FIGURE 2-11: HO Output Sink ON-Resistance vs. VDD. FIGURE 2-12: HO Output Sink ON-Resistance vs. Temperature. FIGURE 2-13: LO Output Sink ON-Resistance vs. VDD. FIGURE 2-14: LO Output Sink ON-Resistance vs. Temperature. FIGURE 2-15: HO Output Source ON-Resistance vs. VDD. FIGURE 2-16: HO Output Source ON-Resistance vs. Temperature. FIGURE 2-17: LO Output Source ON-Resistance vs. VDD. FIGURE 2-18: LO Output Source ON-Resistance vs. Temperature. FIGURE 2-19: VDD/VHB ULVO vs. Temperature. FIGURE 2-20: Propagation Delay vs. VDD Voltage. FIGURE 2-21: Propagation Delay vs. Temperature. FIGURE 2-22: HO Rise Time vs. VDD Voltage. FIGURE 2-23: HO Fall Time vs. VDD Voltage. FIGURE 2-24: LO Rise Time vs. VDD Voltage. FIGURE 2-25: LO Fall Time vs. VDD Voltage. FIGURE 2-26: Rise/Fall Time vs. Temperature (VDD = 10V). FIGURE 2-27: Rise/Fall Time vs. Temperature (VDD = 20V). FIGURE 2-28: Dead Time vs. VDD Voltage. FIGURE 2-29: Dead Time vs. Temperature (VDD = 10V). FIGURE 2-30: Dead Time vs. Temperature (VDD = 20V). FIGURE 2-31: Overcurrent Threshold vs. VDD Voltage. FIGURE 2-32: Overcurrent Threshold vs. Temperature. FIGURE 2-33: Overcurrent Propagation Delay vs. VDD Voltage. FIGURE 2-34: Overcurrent Propagation Delay vs. Temperature. 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 4.0 Functional Description 4.1 UVLO Protection 4.2 Startup and UVLO FIGURE 4-1: Startup and Fault Timing Diagram. TABLE 4-1: Operational Truth Table 4.3 Enable Inputs 4.4 Input Stage FIGURE 4-2: Input Stage Block Diagram. FIGURE 4-3: Minimum Pulse-Width Diagram. 4.5 Dead Time and Anti-Shoot-Through Protection FIGURE 4-4: Dead Time, Propagation Delay, and Rise/Fall-Time Diagram. 4.6 Low-Side Driver Output Stage FIGURE 4-5: Low-Side Driver Block Diagram. 4.7 High-Side Driver and Bootstrap Circuit FIGURE 4-6: High-Side Driver and Bootstrap Circuit Block Diagram. FIGURE 4-7: MIC4609 Motor Driver Typical Application – Phase A. 4.8 Overcurrent Protection Circuitry FIGURE 4-8: Overcurrent Fault Sequence. 5.0 Application Information 5.1 Bootstrap Circuit FIGURE 5-1: MIC4609 – Bootstrap Circuit. 5.2 HS Node Clamp FIGURE 5-2: Negative HS Pin Voltage. 5.3 Power Dissipation Considerations FIGURE 5-3: MIC4609 High-Side Driving an External IGBT. FIGURE 5-4: Typical Gate Charge vs. VGE. 5.4 Decoupling Capacitor Selection 5.5 Grounding, Component Placement, and Circuit Layout FIGURE 5-5: Turn-On Current Paths. FIGURE 5-6: Turn-Off Current Paths. 6.0 Packaging Information 6.1 Package Marking Information 28-Lead SOICW Package Outline and Recommended Land Pattern Appendix A: Revision History Revision C (September 2019) Revision B (November 2017) Revision A (March 2016) Product Identification System Trademark Worldwide Sales and Service
