Datasheet ATA663431, ATA663454 (Microchip) - 4
ПроизводительMicrochip
ОписаниеLIN SBC including LIN Transceiver, Voltage Regulator, Window Watchdog and High-Side Switch
Страниц / Страница40 / 4 — ATA663431/54. TABLE 1-1:. OPERATING MODES (MODE PIN IS ALWAYS LOW). …
ATA663431/54. TABLE 1-1:. OPERATING MODES (MODE PIN IS ALWAYS LOW). Operating. Voltage. High-Side. Transceiver. Watchdog. LIN. TXD. RXD
ATA663431/54 TABLE 1-1: OPERATING MODES (MODE PIN IS ALWAYS LOW) Operating Voltage High-Side Transceiver Watchdog LIN TXD RXD
28 предложений от 22 поставщиков
PIC10F220-I/P
30 ₽
PIC10F220-I/P
59 ₽
МосЧип
PIC10F220IP
727GS
PIC10F220-I/P
link to page 6
ATA663431/54 TABLE 1-1: OPERATING MODES (MODE PIN IS ALWAYS LOW) Operating Voltage High-Side Transceiver Watchdog LH LIN TXD RXD Modes Regulator Output
Fail-Safe OFF ON ON WD HSin-dependent Recessive Signaling fail-safe sources dependent (see
Table 1-2
) Normal ON ON ON WD HSin-dependent TXD Follows data transmission dependent dependent Silent OFF ON OFF Remains HSin-dependent Recessive High High in previ- ous state Sleep/ OFF OFF OFF OFF OFF Recessive Low Low Unpowered 1.2.1 NORMAL MODE 1.2.2 SILENT MODE This is the normal transmission and receiving mode of A falling edge at EN while TXD is high switches the IC the LIN interface. The VCC voltage regulator works into Silent mode. The TXD signal has to be logic high with 3.3V/5V output voltage. The watchdog needs a during the mode select window. The transmission path trigger signal from NTRIG to avoid resets at NRES. If is disabled in Silent mode. The voltage regulator is NRES switches to low, the IC changes its state to active. The overall supply current from VBat is a combi- Fail-Safe mode. nation of the IVSsilent of typically 47 μA plus the VCC regulator output current IVCC.
FIGURE 1-2: SWITCHING TO SILENT MODE Normal Mode Silent Mode
EN Mode select window TXD td = 3.2μs NRES VCC Delay time silent mode td_silent = maximum 20μs LIN LIN switches directly to recessive mode In Silent mode, the internal slave termination between present between the LIN pin and the VS pin. Silent the LIN pin and VS pin is disabled to minimize current mode can be activated regardless of the current level consumption in case the LIN pin is short-circuited to on the LIN pin or WKin pin. GND. Only a weak pull-up current (typically 10 μA) is If an undervoltage condition or a watchdog failure occur, NRES is switched to low and the ATA663431/54 changes its state to Fail-Safe mode. DS50002820B-page 4  2018 Microchip Technology Inc. Document Outline Features General Description Package Types Block Diagram 1.0 Functional Description 1.1 Physical Layer Compatibility 1.2 Operating Modes FIGURE 1-1: Operating Modes TABLE 1-1: Operating Modes (Mode Pin Is Always Low) 1.2.1 Normal Mode 1.2.2 Silent Mode FIGURE 1-2: Switching to Silent mode 1.2.3 Sleep Mode FIGURE 1-3: Switching to Sleep Mode 1.2.4 Fail-Safe mode TABLE 1-2: Signaling in Fail-safe Mode 1.3 Wake-up Scenarios from Silent Mode or Sleep Mode 1.3.1 Remote Wake-up via LIN Bus 1.3.1.1 Remote Wake-up from Silent Mode FIGURE 1-4: LIN Wake-up from Silent Mode 1.3.1.2 Remote Wake-up from Sleep Mode FIGURE 1-5: LIN Wake-up from Sleep Mode 1.3.2 Local Wake-up via WKin Pin FIGURE 1-6: Local Wake-up via WKin pin from Sleep Mode FIGURE 1-7: Local Wake-up via WKin pin from Silent Mode 1.3.3 Local Wake-up via CL15 1.3.4 Wake-up Source Recognition TABLE 1-3: Signaling in Fail-Safe Mode 1.4 Behavior under Low Supply Voltage Conditions FIGURE 1-8: VCC and NRES versus VS (Ramp-up) for ATA663431 FIGURE 1-9: VCC and NRES versus VS (Ramp-down) for ATA663431 FIGURE 1-10: VCC and NRES versus VS (Ramp-up) for ATA663454 FIGURE 1-11: VCC and NRES versus VS (Ramp-Down) for ATA663454 1.5 Voltage Regulator FIGURE 1-12: VCC Voltage Regulator: Supply Voltage Ramp-up and Ramp-down FIGURE 1-13: Power Dissipation: Safe Operating Area: Regulator’s Output Current IVCC versus Supply Voltage VVS at Different Ambient Temperatures (RthvJA = 45 K/W assumed) 1.6 Watchdog FIGURE 1-14: Limp Home (LH) State Diagram 1.6.1 Typical Timing Sequence with RWDOSC = 51 kΩ EQUATION 1-1: FIGURE 1-15: Timing Sequence with RWDOSC = 51 kΩ 1.6.2 Worst-Case Calculation with RWDOSC = 51 kΩ EQUATION 1-2: TABLE 1-4: Typical Watchdog Timings 1.7 Pin Descriptions TABLE 1-5: Pin Description 1.7.1 Bus Data Output Pin (RXD) 1.7.2 Enable Input Pin (EN) 1.7.3 Undervoltage Reset Output Pin (NRES) 1.7.4 Bus Data Input/Output (TXD) 1.7.5 NTRIG Input Pin 1.7.6 Mode Input Pin (MODE) 1.7.7 WDOSC Output Pin 1.7.8 High-side Switch Pins (HSout, HSin) 1.7.9 Limp Home Watchdog Failure Output (LH) 1.7.10 CL15 Pin 1.7.11 Wake Input Pin (WKin) 1.7.12 Ground Pin (GND) 1.7.13 Bus Pin (LIN) 1.7.14 Supply Pin (VS) 1.7.15 Voltage Regulator Output Pin (VCC) Typical Application Circuit 2.0 Electrical Characteristics 2.1 Absolute Maximum Ratings† Electrical Characteristics FIGURE 2-1: Definition of Bus timing Characteristics Temperature Specifications 3.0 Packaging Information 3.1 Package Marking Information LIN SBC including LIN Transceiver, Voltage Regulator, Window Watchdog and High-Side Switch Appendix A: Revision History Revision A (November 2018) Revision B (November 2018) Product Identification System AMERICAS Corporate Office Atlanta Austin, TX Boston Chicago Dallas Detroit Houston, TX Indianapolis Los Angeles Raleigh, NC New York, NY San Jose, CA Canada - Toronto ASIA/PACIFIC Australia - Sydney China - Beijing China - Chengdu China - Chongqing China - Dongguan China - Guangzhou China - Hangzhou China - Hong Kong SAR China - Nanjing China - Qingdao China - Shanghai China - Shenyang China - Shenzhen China - Suzhou China - Wuhan China - Xian China - Xiamen China - Zhuhai ASIA/PACIFIC India - Bangalore India - New Delhi India - Pune Japan - Osaka Japan - Tokyo Korea - Daegu Korea - Seoul Malaysia - Kuala Lumpur Malaysia - Penang Philippines - Manila Singapore Taiwan - Hsin Chu Taiwan - Kaohsiung Taiwan - Taipei Thailand - Bangkok Vietnam - Ho Chi Minh EUROPE Austria - Wels Denmark - Copenhagen Finland - Espoo France - Paris Germany - Garching Germany - Haan Germany - Heilbronn Germany - Karlsruhe Germany - Munich Germany - Rosenheim Israel - Ra’anana Italy - Milan Italy - Padova Netherlands - Drunen Norway - Trondheim Poland - Warsaw Romania - Bucharest Spain - Madrid Sweden - Gothenberg Sweden - Stockholm UK - Wokingham Worldwide Sales and Service
