Datasheet AOZ6683CI (Alpha & Omega) - 2
ПроизводительAlpha & Omega
ОписаниеEZBuck 3A Synchronous Buck Regulator
Страниц / Страница15 / 2 — AOZ6683CI. Ordering Information. Part Number. Ambient Temperature Range. …
Формат / Размер файлаPDF / 631 Кб
AOZ6683CI. Ordering Information. Part Number. Ambient Temperature Range. Package. Environmental. Pin Configuration. TSOT23. (Top View)
AOZ6683CI Ordering Information Part Number Ambient Temperature Range Package Environmental Pin Configuration TSOT23 (Top View)
12 предложений от 6 поставщиков
IC REG BUCK ADJ 3A TSOT23-6
AOZ6683CI
Alpha & Omega
от 6.96 ₽
AOZ6683CI
17 ₽
Hi-Tech Circuit Group
AOZ6683CI
Alpha & Omega
AOZ6683CI
AOZ6683CI -40°C to +125°C TSOT23-6L RoHS AOS Green Products use reduced levels of Halogens, and are also RoHS compliant. Please visit www.aosmd.com/media/AOSGreenPolicy.pdf for additional information.
Pin Configuration
GND 1 6 BST LX 2 5 EN VIN 3 4 FB
TSOT23 (Top View) Pin Description Pin Number Pin Name Pin Function
1 GND System ground. 2 LX Switching node connects to main inductor terminal. Supply voltage input. When VIN rises above the UVLO threshold and EN is logic high, the 3 VIN device will start up. Feedback input. The FB pin is used to set the output voltage through a resistor voltage 4 FB divider between the Output and GND. Enable input. Pull EN to logic high will enable the device. Pull EN to logic low will disable 5 EN the device. EN pin must be connected to VIN if no Enable control is required. 6 BST Bootstrap input. Connect a capacitor to LX (Pin 2). Typical value is 0.1uF. Rev. 2.0 January 2019
www.aosmd.com
Page 2 of 15
