Datasheet M95M04-DR (STMicroelectronics) - 5
ПроизводительSTMicroelectronics
Описание4-Mbit serial SPI bus EEPROM
Страниц / Страница46 / 5 — M95M04-DR. List of figures
Формат / Размер файлаPDF / 858 Кб
M95M04-DR List of figures
38 предложений от 12 поставщиков
IC: память EEPROM; SPI; 512Кx8бит; 1,8÷5,5В; TSSOP8
Элитан
M95M04-DRDW6TP
368 ₽
M95M04-DRDW6TP
от 385 ₽
M95M04-DRDW6TP
от 420 ₽
M95M04-DRDW6TP
link to page 6 link to page 7 link to page 7 link to page 8 link to page 11 link to page 12 link to page 14 link to page 17 link to page 18 link to page 19 link to page 21 link to page 23 link to page 24 link to page 25 link to page 26 link to page 27 link to page 28 link to page 29 link to page 33 link to page 37 link to page 37 link to page 37 link to page 38 link to page 39 link to page 40 link to page 41 link to page 42 link to page 43
M95M04-DR List of figures List of figures
Figure 1. Logic diagram . 6 Figure 2. 8-pin package connections (top view) . 7 Figure 3. WLCSP connections. 7 Figure 4. Block diagram . 8 Figure 5. Bus master and memory devices on the SPI bus. 11 Figure 6. SPI modes supported . 12 Figure 7. Hold condition activation. 14 Figure 8. Write enable (WREN) sequence. 17 Figure 9. Write disable (WRDI) sequence . 18 Figure 10. Read Status register (RDSR) sequence . 19 Figure 11. Write Status register (WRSR) sequence . 21 Figure 12. Read from Memory array (READ) sequence . 23 Figure 13. Byte Write (WRITE) sequence . 24 Figure 14. Page Write (WRITE) sequence . 25 Figure 15. Read Identification page sequence . 26 Figure 16. Write Identification page sequence . 27 Figure 17. Read Lock status sequence . 28 Figure 18. Lock ID sequence . 29 Figure 19. AC measurement I/O waveform . 33 Figure 20. Serial input timing . 37 Figure 21. Hold timing . 37 Figure 22. Serial output timing . 37 Figure 23. SO8N outline . 38 Figure 24. SO8N recommended footprint . 39 Figure 25. WLCSP (with BSC) outline . 40 Figure 26. WLCSP recommended footprint . 41 Figure 27. TSSOP8 outline . 42 Figure 28. TSSOP8 recommended footprint . 43 DS12179 Rev 1 5/46 5 Document Outline 1 Description Figure 1. Logic diagram Table 1. Signal names Figure 2. 8-pin package connections (top view) Figure 3. WLCSP connections Table 2. Signals vs. bump position 2 Memory organization Figure 4. Block diagram 3 Signal description 3.1 Serial data output (Q) 3.2 Serial data input (D) 3.3 Serial clock (C) 3.4 Chip select (S) 3.5 Hold (HOLD) 3.6 Write protect (W) 3.7 VCC supply voltage 3.8 VSS ground 4 Connecting to the SPI bus Figure 5. Bus master and memory devices on the SPI bus 4.1 SPI modes Figure 6. SPI modes supported 5 Operating features 5.1 Supply voltage (VCC) 5.1.1 Operating supply voltage (VCC) 5.1.2 Device reset 5.1.3 Power-up conditions 5.1.4 Power-down 5.2 Active power and Standby power modes 5.3 Hold condition Figure 7. Hold condition activation 5.4 Status register 5.5 Data protection and protocol control Table 3. Write-protected block size 6 Instructions Table 4. Instruction set Table 5. Significant bits within the address bytes 6.1 Write enable (WREN) Figure 8. Write enable (WREN) sequence 6.2 Write disable (WRDI) Figure 9. Write disable (WRDI) sequence 6.3 Read Status register (RDSR) Figure 10. Read Status register (RDSR) sequence 6.3.1 WIP bit 6.3.2 WEL bit 6.3.3 BP1, BP0 bits 6.3.4 SRWD bit Table 6. Status register format 6.4 Write Status register (WRSR) Figure 11. Write Status register (WRSR) sequence Table 7. Protection modes 6.5 Read from Memory array (READ) Figure 12. Read from Memory array (READ) sequence 6.6 Write to Memory array (WRITE) Figure 13. Byte Write (WRITE) sequence Figure 14. Page Write (WRITE) sequence 6.7 Read Identification page Figure 15. Read Identification page sequence 6.8 Write Identification page Figure 16. Write Identification page sequence 6.9 Read Lock status Figure 17. Read Lock status sequence 6.10 Lock ID Figure 18. Lock ID sequence 6.11 Error correction code (ECC x 4) and write cycling 7 Power-up and delivery state 7.1 Power-up state 7.2 Initial delivery state 8 Maximum ratings Table 8. Absolute maximum ratings 9 DC and AC parameters Table 9. Operating conditions (range R) Table 10. AC measurement conditions Figure 19. AC measurement I/O waveform Table 11. Cycling performance by groups of four bytes Table 12. Memory cell data retention Table 13. Capacitance Table 14. DC characteristics Table 15. AC characteristics Figure 20. Serial input timing Figure 21. Hold timing Figure 22. Serial output timing 10 Package information 10.1 SO8N package information Figure 23. SO8N outline Table 16. SO8N mechanical data Figure 24. SO8N recommended footprint 10.2 WLCSP8 package information Figure 25. WLCSP (with BSC) outline Table 17. WLCSP mechanical data Figure 26. WLCSP recommended footprint 10.3 TSSOP8 package information Figure 27. TSSOP8 outline Table 18. TSSOP8 mechanical data Figure 28. TSSOP8 recommended footprint 11 Ordering information 12 Revision history Table 19. Document revision history
