Datasheet VSMY5890X01 (Vishay) - 3
ПроизводительVishay
ОписаниеHigh Speed Infrared Emitting Diodes, 890 nm, Surface Emitter Technology
Страниц / Страница6 / 3 — VSMY5890X01. BASIC CHARACTERISTICS. REFLOW SOLDER PROFILE. DRYPACK. FLOOR …
Формат / Размер файлаPDF / 128 Кб
VSMY5890X01. BASIC CHARACTERISTICS. REFLOW SOLDER PROFILE. DRYPACK. FLOOR LIFE. DRYING
VSMY5890X01 BASIC CHARACTERISTICS REFLOW SOLDER PROFILE DRYPACK FLOOR LIFE DRYING
33 предложений от 10 поставщиков
ИК-передатчик; 0805; 890нм; 60°; SMD; Разм: 2x1,25x0,8мм; 100мА
VSMY5890X01
70 ₽
Эиком
VSMY5890X01
от 75 ₽
VSMY5890X01
от 126 ₽
Hi-Tech Circuit Group
VSMY5890X01
VSMY5890X01
www.vishay.com Vishay Semiconductors
(Tamb = 25 °C, unless otherwise specified) Axis Title Axis Title 1000 10000 100 10000 t = 100 μs p ) 90 I = 100 mA F (% ) 80 A ty (m 70 100 1000 tensi 1000 In 60 rrent u ne ne ine ant ne ne ine 50 adi rd C 1st li 2nd li 2nd l 1st li a 2nd li 2nd l 40 10 100 orw 100 F 30 - elative R I F R - 20 l. e 10 I e, r 1 10 0 10 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 2.8 3.0 750 800 850 900 950 1000 V - Forward Voltage (V) F λ - Wavelength (nm) Fig. 3 - Forward Current vs. Forward Voltage Fig. 5 - Relative Radiant Power vs. Wavelength Axis Title Axis Tit 0° le 10° 20° 10 10000 10000 30° t = 100 μs p tensity ent tensity n 1 1000 In 1000 40° )) A 1.0 ne ne ine isplacem ne 0.9 1st li 50° (100 m 2nd li e 2nd l 2nd li / I 0.8 gular D e 0.1 100 100 elative Radiant 60° n elative Radiant I (I R A R - - - l. l 70° φ e 0.7 e I e,r I e, r 80° 0.01 10 10 1 10 100 0.6 0.4 0.2 0 I - Forward Current (mA) F 1st line Fig. 4 - Relative Radiant Intensity vs. Forward Current Fig. 6 - Relative Radiant Intensity vs. Angular Displacement
Axis Title Devices are packed in moisture barrier bags (MBB) to 300 10000 prevent the products from moisture absorption during Max. 260 °C transportation and storage. Each bag contains a desiccant. 255 °C 250 245 °C 240 °C 217 °C
FLOOR LIFE
200 1000 Time between soldering and removing from MBB must not Max. 30 s ine ne ne exceed the time indicated in J-STD-020: 150 Moisture sensitivity: level 3 1st li 2nd l 2nd li Max. 120 s Max. 100 s Floor life: 168 h 100 100 Temperature (°C) Max. ramp down 6 °C/s Conditions: Tamb < 30 °C, RH < 60 % 50 Max. ramp up 3 °C/s
DRYING
In case of moisture absorption devices should be baked 0 10 0 50 100 150 200 250 300 before soldering. Conditions see J-STD-033D or label. Time (s) Devices taped on reel dry using recommended conditions 19841 192 h at 40 °C (+ 5 °C), RH < 5 %. Fig. 7 - Lead (Pb)-free Reflow Solder Profile According to J-STD-020 Rev. 1.0, 11-Apr-2019
3
Document Number: 84952 For technical questions, contact: emittertechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
