Datasheet VSMY5940X01 (Vishay) - 2
ПроизводительVishay
ОписаниеHigh Speed Infrared Emitting Diodes, 940 nm, Surface Emitter Technology
Страниц / Страница6 / 2 — VSMY5940X01. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. …
Формат / Размер файлаPDF / 127 Кб
VSMY5940X01. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. VALUE. UNIT. BASIC CHARACTERISTICS. MIN. TYP. MAX
VSMY5940X01 ABSOLUTE MAXIMUM RATINGS PARAMETER TEST CONDITION SYMBOL VALUE UNIT BASIC CHARACTERISTICS MIN TYP MAX
21 предложений от 7 поставщиков
ИК-передатчик; 0805; 940нм; 60°; SMD; Разм: 2x1,25x0,8мм; 100мА
Элитан
VSMY5940X01
67 ₽
VSMY5940X01
76 ₽
VSMY5940X01
от 91 ₽
Эиком
VSMY5940X01
от 105 ₽
VSMY5940X01
www.vishay.com Vishay Semiconductors
(Tamb = 25 °C, unless otherwise specified)
Reverse voltage VR 5 V Forward current IF 100 mA Peak forward current tp/T = 0.1, tp = 100 μs IFM 200 mA Surge forward current tp = 100 μs IFSM 500 mA Power dissipation PV 190 mW Junction temperature Tj 125 °C Operating temperature range Tamb -40 to +110 °C Storage temperature range Tstg -40 to +110 °C Soldering temperature According to Fig. 7, J-STD-020 Tsd 260 °C Thermal resistance junction-to-ambient EIA / JESD51 RthJA 280 K/W Axis Title Axis Title 200 10000 110 10000 180 100 ) 160 R = 280 K/W thJA 90 R = 280 K/W thJA W ) A (m 80 140 (m n 1000 1000 o 70 120 pati ne ne rrent ne ine 60 u ne ine 100 issi 1st li 50 2nd li 2nd l rd C 1st li 2nd li 80 2nd l a er D 40 100 100 ow 60 orw P F 30 - - V 40 I F P 20 20 10 0 10 0 10 0 20 40 60 80 100 120 0 20 40 60 80 100 120 T - Ambient Temperature (°C) T - Ambient Temperature (°C) amb amb Fig. 1 - Power Dissipation Limit vs. Ambient Temperature Fig. 2 - Forward Current Limit vs. Ambient Temperature
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Forward voltage IF = 100 mA, tp = 20 ms VF - 1.6 1.9 V Temperature coefficient of VF IF = 100 mA, tp = 20 ms TKVF - -0.7 - mV/K Reverse current IR Not designed for reverse operation μA V Junction capacitance R = 0 V, f = 1 MHz, E = 0 mW/cm2 CJ - 30 - pF Radiant intensity IF = 100 mA, tp = 20 ms Ie 9 13 18 mW/sr Temperature coefficient of radiant I power F = 100 mA, tp = 20 ms TKφe - -0.2 - %/K Angle of half intensity ϕ - ± 60 - ° Peak wavelength IF = 100 mA, tp = 20 ms λp - 940 - nm Spectral bandwidth IF = 100 mA, tp = 20 ms Δλ - 55 - nm Temperature coefficient of λp IF = 100 mA, tp = 20 ms TKλp - 0.28 - nm/K Rise time IF = 100 mA, 10 % to 90 % tr - 5 - ns Fall time IF = 100 mA, 10 % to 90 % tf - 5 - ns Rev. 1.0, 11-Apr-2019
2
Document Number: 84886 For technical questions, contact: emittertechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
