Микросхема Преобразователь DA, MAXIM INTEGRATED PRODUCTS MAX519BCPE+ Digital to Analog Converter, Rail to Rail Outputs, 8Bit, Serial, 4.5V to 5.5V, DIP,...
2-Wire Serial 8-Bit DACs with Rail-to-Rail OutputsELECTRICAL CHARACTERISTICS (continued) (VDD = 5V ±10%, VREF_ = 4V (MAX517, MAX519), RL = 10kΩ, CL = 100pF, TA = TMIN to TMAX, unless otherwise noted. Typical values are TA = +25°C.) PARAMETERSYMBOLCONDITIONSMINTYPMAX UNITS Digital-Analog Glitch Impulse Code 128 to 127 12 nV-s Signal to Noise + Distortion V SINAD REF_ = 4Vp-p at 1kHz, VDD = 5V, 87 dB Ratio (MAX517, MAX519) Code = FF hex Multiplying Bandwidth VREF_ = 4Vp-p, 3dB bandwidth 1 MHz (MAX517, MAX519) Wideband Amplifier Noise 60 µVRMS POWER REQUIREMENTS Supply Voltage VDD 4.5 5.5 V MAX517C 1.5 3.0 Normal mode, output(s) MAX517E/M 1.5 3.5 unloaded, all digital inputs mA Supply Current IDD MAX518C, MAX519C 2.5 5 at 0V or VDD MAX518E/M, MAX519E/M 2.5 6 Power-down mode 4 20 µA TIMING CHARACTERISTICS (VDD = 5V ±10%, TA = TMIN to TMAX, unless otherwise noted. Typical values are TA = +25°C.) PARAMETERSYMBOLCONDITIONSMINTYPMAXUNITSMAX517/MAX518/MAX519 Serial Clock Frequency fSCL 0 400 kHz Bus Free Time Between a STOP and a t START Condition BUF 1.3 µs Hold Time, (Repeated) Start Condition tHD, STA 0.6 µs Low Period of the SCL Clock tLOW 1.3 µs High Period of the SCL Clock tHIGH 0.6 µs Setup Time for a Repeated START Condition tSU, STA 0.6 µs Data Hold Time tHD, DAT (Note 9) 0 0.9 µs Data Setup Time tSU, DAT 100 ns Rise Time of Both SDA and SCL Signals, Receiving tR (Note 10) 20 + 0.1Cb 300 ns Fall Time of Both SDA and SCL Signals, Receiving tF (Note 10) 20 + 0.1Cb 300 ns Fall Time of SDA Transmitting tF ISINK ≤ 6mA (Notes 7, 10) 20 + 0.1Cb 250 ns Setup Time for STOP Condition tSU, STO 0.6 µs Capacitive Load for Each Bus Line Cb 400 pF Pulse Width of Spike Suppressed tSP (Notes 6, 11) 0 50 ns Note 1: For the MAX518 (full-scale = VDD) the last three codes are excluded from the TUE and DNL specifications, due to the limited output swing when loaded with 10kΩ to GND. Note 2: Input resistance is code dependent. The lowest input resistance occurs at code = 55 hex. Note 3: Input capacitance is code dependent. The highest input capacitance occurs at code FF hex. Note 4: VREF_ = 4VP-P, 10kHz. Channel-to-channel isolation is measured by setting the code of one DAC to FF hex and setting the code of all other DACs to 00 hex. Note 5: VREF_ = 4Vp-p, 10kHz, DAC code = 00 hex. Note 6: Guaranteed by design. Note 7: I2C compatible mode. RPULLUP = 1.7kΩ. Note 8: Output settling time is measured by taking the code from 00 hex to FF hex, and from FF hex to 00 hex. Note 9: A master device must provide a hold time of at least 300ns for the SDA signal (referred to VIL of the SCL signal) in order to bridge the undefined region of SCL’s falling edge. Note 10: Cb = total capacitance of one bus line in pF. tR and tF measured between 0.3VDD and 0.7VDD. Note 11: Input filters on the SDA and SCL inputs suppress noise spikes less than 50ns. 4_______________________________________________________________________________________
