Datasheet MAX845 (Maxim) - 13
ПроизводительMaxim
ОписаниеIsolated Transformer Driver for PCMCIA Applications
Страниц / Страница16 / 13 — Isolated Transformer Driver. for PCMCIA Applications. MAX845. Rectifier …
Формат / Размер файлаPDF / 219 Кб
Isolated Transformer Driver. for PCMCIA Applications. MAX845. Rectifier Topology. Diodes
Isolated Transformer Driver for PCMCIA Applications MAX845 Rectifier Topology Diodes
63 предложений от 30 поставщиков
Интегральные схемы (ИС) усилителей мощности Isolated Transformer Driver for PCMCIA
ЧипСити
MAX845ESA
Maxim
161 ₽
Эиком
MAX845ESA+T
от 832 ₽
MAX845ESA+T
Maxim
от 1 052 ₽
LifeElectronics
MAX845ESA+
Maxim
2) Use a test winding to measure ET product (if using an ungapped toroid) and/or AL value for the core. VIN 6 3) Determine the number of turns required for the pri- V 1 CC D1 mary winding. For an ungapped toroid, ET product from center-tap to D1 must be at least 5V-µs. Other core types must have sufficient inductance to limit MAX845 D1 and D2 output current under minimum load con- 8 D2 ditions, and must not be allowed to saturate. GND1 GND2 2 7 4) Select a rectifier topology based on performance requirements (ripple vs. loss, and space required for secondary winding). Refer to Table 2, Rectifier Figure 11a. 2-Diode Push-Pull Topology Trade-Offs. 5) Work backward from VOUT requirements to deter- mine the secondary to primary turns ratio. Include VIN 6 losses in the rectifier diodes, and estimate resistive 1 VCC D1 losses in the windings. For load currents exceed- ing 150mA, use a voltage step-down transformer to step up the output current from the MAX845. Do MAX845 not exceed the MAX845’s absolute maximum out- 8 D2 put current rating (200mA). GND1 GND2 2 7 6) Wind the transformer with the largest diameter wire that will fit the winding area. Select a wire gauge to fill the winding aperture as much as possible. Figure 11b. 4-Diode Bridge Larger diameter wire has lower resistance per unit length. Doubling the wire diameter reduces resis- tive losses by a factor of four. VIN 6 Bobbin or drum cores suffer from low coupling between 1 VCC D1 windings. This usually requires bifilar winding for the two halves of the primary. MAX845 Due to the inherent complexity of magnetic circuit 8 design, it will be necessary to build a prototype and re- D2 GND1 GND2 iterate the design. If necessary, adjust the design by 2 7 altering the number of primary or secondary turns, or the wire gauge. If using a different core material or geome- try, evaluate its ET product or AL as described above. Figure 11c. Voltage Doubler
Figure 11 shows various rectifier topologies. Refer to Use fast-switching diode rectifiers. Ordinary silicon sig- Table 2 for selection criteria. The turns ratio of the trans- nal diodes like the 1N914 or 1N4148 may be used for former must be set to provide the minimum required out- low output current levels (less than 50mA), but Schottky put voltage at the maximum anticipated load, with the diodes have a lower forward voltage drop and should minimum expected input voltage. In addition, the calcu- be used for higher-current applications. Central lations should allow for worst-case losses in the recti- Semiconductor has low-current Schottky diodes as fiers. Since the turns ratio determined in this manner will duals in SOT-23 packages (CMPSH-3 series). The ordinarily produce a much higher voltage at the sec- Nihon SB05W05C is a common-cathode dual in a SOT- ondary under conditions of high input voltage and/or 23; it works well in the two-diode full-wave configura- light loading, be careful to prevent an overvoltage con- tion. The Motorola MBR0520 is an excellent choice for dition from occurring (see the Output Voltage vs. Load all configurations. Current graph in the Typical Operating Characteristics).
______________________________________________________________________________________ 13
