Datasheet PAM8904Q (Diodes) - 4
ПроизводительDiodes
ОписаниеAutomotive 18VPP Output Peizo Sounder Driver
Страниц / Страница11 / 4 — PAM8904Q. Electrical Characteristics. Symbol. Parameter. Conditions. Min. …
Формат / Размер файлаPDF / 407 Кб
PAM8904Q. Electrical Characteristics. Symbol. Parameter. Conditions. Min. Typ. Max. Unit. www.diodes.com
PAM8904Q Electrical Characteristics Symbol Parameter Conditions Min Typ Max Unit www.diodes.com
46 предложений от 16 поставщиков
Интегральные микросхемы Линейные микросхемы - Усилители - Звуковые
PAM8904QJER
Diodes
от 14 ₽
PAM8904QJER
Diodes
от 92 ₽
PAM8904QJER
Diodes
от 161 ₽
Hi-Tech Circuit Group
PAM8904QJER
Diodes
(@TA = +25°C, unless otherwise specified.)
VOUT Output Voltage Range Note 5 2.1 — 12 V VOUT1 1x Mode 2.8 — 3 V VOUT2 Output Voltage 2x Mode 5.2 — 6 V VOUT3 3x Mode 7.2 — 9 V IDD11 1x Mode, CPIEZO = No Load — 50 — µA IDD12 Operating Current 1 2x Mode, CPIEZO = No Load — 720 — µA IDD13 3x Mode, CPIEZO = No Load — 1,700 — µA IDD21 1x Mode, Single-ended application — 0.3 — mA IDD22 Operating Current 2 2x Mode, Single-ended application — 1.4 — mA IDD23 3x Mode, Single-ended application — 3.9 — mA IDD31 1x Mode, Differential application — 0.9 — mA IDD32 Operating Current 3 2x Mode, Differential application — 3.8 — mA IDD33 3x Mode, Differential application — 8.5 — mA ISD Shutdown Current DIN = 0V — — 1 µA fIN Input Frequency Rectangular pulse on DIN 0.02 — 300 kHz fOSC Oscillating Frequency — — 1 — MHz 1x Mode, From D t IN signal High to 90% ON1 — 270 — µs VOUT steady state 2x Mode, From D t IN signal High to 90% ON2 VOUT Start Delay Time — 320 — µs VOUT steady state 3x Mode, From D t IN signal High to 90% ON3 — 350 — µs VOUT steady state tOFF Shutdown Delay Time DIN = H- >L — 42 — ms ISC Output Short-Circuit Current — — 40 — mA OTP Thermal Shutdown Junction temperature — +150 — °C OTPHYS Thermal Shutdown Hysteresis — — +37 — °C 0.8 x VIH Control Terminal Voltage H CPM1, CPM2, DIN pins — V V IN V IN 0.2 x VIL Control Terminal Voltage L CPM1, CPM2, DIN pins 0 — V VIN IIH1 Control Terminal Current 1 DIN = 3V — — 1 µA IIH2 Control Terminal Current 2 VCPM1, VCPM2 = 3V, DIN = 3V — — 1 µA IIH3 Control Terminal Current 3 VCPM1, VCPM2 = 3V, DIN = 0V — — 1 µA CL Capacitive Load — — 15 50 nF Note: 5. It is possible to drive VOUT, VO1 and VO2 to 3x VDD. A supply voltage of 4V of more should not be used in 3x mode as this will exceed the maximum output voltage rating. PAM8904Q 4 of 11 November 2016 Document number: DS38977 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated
