Линейка продуктов KEEN SIDE
Datasheet AK7864A (Asahi Kasei Microdevices) - 7
ПроизводительAsahi Kasei Microdevices
Описание3 channel LED Driver with Charge Pump
Страниц / Страница13 / 7 — Absolute Maximum Ratings. Recommended Operating Conditions. Electrical …
Формат / Размер файлаPDF / 302 Кб
Absolute Maximum Ratings. Recommended Operating Conditions. Electrical Characteristics. 1. Digital input DC characteristics
Absolute Maximum Ratings Recommended Operating Conditions Electrical Characteristics 1 Digital input DC characteristics
[AK7864A]
Voltages are referenced to corresponding ground level. VSS=0V Item Symbol Min. Max. Unit Remarks Power supply VDD 0.3 4.0 V Input Voltage VINA 0.3 VDD+0.3 V Storage temperature Tstg 65 150 C Operation under a condition exceeding above limits may cause permanent damage to the device. Normal operation is not guaranteed under the above extreme conditions.
Voltages are referenced to corresponding ground level. VSS=0V Item Symbol Min. Typ. Max. Unit Remarks Power supply VDD 3.135 3.3 3.465 V Storage temperature Ta 0 70 C
Electrical Characteristics 1. Digital input DC characteristics
(VDD=3.135~3.465V, Ta=070C unless otherwise specified) Item Symbol Pin Min. Typ. Max. Unit Remarks H level input voltage VIH Note1 0.7 V VDD L level input voltage VIL Note1 0.3 V VDD Input leakage current IL Note1 2 2 A (Note 1)PDN, EN, CONT_R, CONT_G, CONT_B
2. Carge pump block analog characteristics
(VDD=3.135~3.465V, Ta=070C unless otherwise specified) Item Min. Typ. Max. Unit Remarks CPOUT Voltage 6.27 6.6 6.93 V @LED current disable CPOUT Rise time 1 ms CPOUT Fall time 20 ms Current Consumption 4.0 mA MS1336 - E - 00 7 2012/01
