Datasheet 48L512, 48LM01 (Microchip) - 6
| Производитель | Microchip |
| Описание | 512-Kbit/1-Mbit SPI Serial EERAM |
| Страниц / Страница | 40 / 6 — 48L512/48LM01. FIGURE 1-1:. HOLD TIMING. FIGURE 1-2:. SERIAL INPUT TIMING … |
| Формат / Размер файла | PDF / 648 Кб |
48L512/48LM01. FIGURE 1-1:. HOLD TIMING. FIGURE 1-2:. SERIAL INPUT TIMING MODE 0,0. FIGURE 1-3:. SERIAL INPUT TIMING MODE 1,1
48L512/48LM01 FIGURE 1-1: HOLD TIMING
CS 18 19 18 19 18 19 18 19 SCK 16 17 High-Impedance 16 17 High-Impedance SO n+1 n n n-1 n-2 Don’t Care 5 Don’t Care SI n+1 n n n-1 n-2 HOLD
FIGURE 1-2: SERIAL INPUT TIMING MODE 0,0
4 CS 12 2 7 11 8 3 10 SCK 9 5 6 SI MSb In LSb In High-Impedance SO
FIGURE 1-3: SERIAL INPUT TIMING MODE 1,1
4 CS 12 2 11 7 8 3 10 SCK 9 5 6 SI MSb In LSb In High-Impedance SO 2018-2019 Microchip Technology Inc. DS20006008C-page 6 Document Outline Serial SRAM Features Hidden EEPROM Backup Features Other Features of the 48L512/48LM01 Packages Package Types (not to scale) Pin Function Table General Description Block Diagram Normal Device Operation Vcc Power-Off Event 1.0 Electrical Characteristics Absolute Maximum Ratings† TABLE 1-1: DC Characteristics TABLE 1-2: AC Characteristics TABLE 1-3: AC Test Conditions 2.0 Pin Descriptions TABLE 2-1: Pin Function Table 2.1 Chip Select (CS) 2.2 Serial Output (SO) 2.3 Serial Input (SI) 2.4 Serial Clock (SCK) 2.5 Hold (HOLD) 3.0 Memory Organization 3.1 Data Array Organization 3.2 16-Byte Nonvolatile User Space 3.3 Device Registers 3.3.1 STATUS Register 4.0 Functional Description FIGURE 4-1: SPI Mode 0 and Mode 3 4.1 Interfacing the 48L512/48LM01 on the SPI Bus 4.1.1 Selecting the Device 4.1.2 Sending Data to the Device 4.1.3 Receiving Data from the Device 4.2 Device Opcodes 4.2.1 Serial Opcode 4.2.2 Hold Function FIGURE 4-2: Hold Mode 5.0 Write Enable and Disable 5.1 Write Enable Instruction (WREN) FIGURE 5-1: WREN Waveform 5.2 Write Disable Instruction (WRDI) FIGURE 5-2: WRDI Waveform 6.0 STATUS Register 6.1 Block Write-Protect Bits TABLE 6-2: Block Write-Protect Bits 6.2 Write Enable Latch 6.3 Ready/Busy Status Latch 6.4 Read STATUS Register (RDSR) FIGURE 6-1: RDSR Waveform 6.5 Write STATUS Register (WRSR) FIGURE 6-2: WRSR Waveform 7.0 Read Operations 7.1 Reading from the SRAM (READ) FIGURE 7-1: Read SRAM (READ) Waveform 8.0 Write Commands 8.1 Write Instruction Sequences 8.1.1 SRAM Byte Write FIGURE 8-1: SRAM Byte Write Waveform 8.1.2 Continuous Write FIGURE 8-2: Continuous SRAM Write Waveform 9.0 Nonvolatile User Space Access 9.1 Write Nonvolatile User Space (WRNUR) 9.2 Read Nonvolatile User Space (RDNUR) 10.0 Secure Operations 10.1 Secure Write 10.2 Secure Read TABLE 10-1: Secure Write Bits 11.0 Store/Recall Operations 11.1 Automatic Store on Any Power Disruption 11.2 Automatic Recall to SRAM 11.3 Software Store Command FIGURE 11-1: Software Store 11.4 Software Recall Command FIGURE 11-2: Software Recall 11.5 Polling Routine FIGURE 11-3: Polling Flow FIGURE 11-4: AutoStore/AutoRecall Scenarios (with ASE = 0, Array Modified) FIGURE 11-5: AutoStore/AutoRecall Scenarios (with ASE = 1 or Array Not Modified) 12.0 Hibernation FIGURE 12-1: Hibernate Waveform 13.0 Trip Voltage 13.1 Power Switchover 14.0 Packaging Information 14.1 Package Marking Information Appendix A: Revision History Product ID System Trademarks Worldwide Sales
