Оптопары и оптореле Megawin
Datasheet RV1S9213A (Renesas) - 5
ПроизводительRenesas
Описание1 Mbps, OPEN COLLECTOR OUTPUT, HIGH CMR, IPM DRIVER, 5-PIN SSOP WITH 8.2mm CREEPAGE DISTANCE (LSSO5) PHOTOCOUPLER
Страниц / Страница16 / 5 — RV1S9213A. 章題. ELECTRICAL. CHARACTERISTICS. (TA. =. -40. ~. +125°C,VCC. …
Формат / Размер файлаPDF / 6.6 Мб
RV1S9213A. 章題. ELECTRICAL. CHARACTERISTICS. (TA. =. -40. ~. +125°C,VCC. =. 15V,. unless. otherwise. specified). Parameter. Symbol. Conditions. MIN. TYP.*1
RV1S9213A 章題 ELECTRICAL CHARACTERISTICS (TA = -40 ~ +125°C,VCC = 15V, unless otherwise specified) Parameter Symbol Conditions MIN TYP.*1
30 предложений от 10 поставщиков
Оптопара, 1 канал, 5 кВ, 1 Мбит/с, LSSOP, 5 вывод(-ов)
RV1S9213ACCSP-10YC#KC0
Renesas
66 ₽
Renesas
от 88 ₽
Эиком
Renesas
от 95 ₽
RV1S9213ACCSP-10YV#SC0
Renesas
от 168 ₽
RV1S9213A 章題 ELECTRICAL CHARACTERISTICS (TA = -40 ~ +125°C,VCC = 15V, unless otherwise specified) Parameter Symbol Conditions MIN. TYP.*1 MAX. Unit Diode Forward Voltage VF IF = 10 mA, TA = 25C 1.35 1.56 1.75 V Reverse Current IR VR = 3 V, TA = 25C 10 A Terminal Capacitance Ct VF = 0 V, f = 1 MHz 30 pF Detector High Level Supply Current ICCH VCC = 20V, VF = 0.8V, 1.0 1.3 mA VO = Open Low Level Supply Current ICCL VCC = 20V, IF =10mA, 1.0 1.3 mA VO = Open High Level Output Current IOH VCC =20V, VF =0.8V 0.01 50 µA Low Level Output Voltage VOL VCC = 15V, IF =10mA, 0.13 0.6 V IOL = 2.4mA Coupled Threshold Input Current IFHL VCC = 15V, VO = 0.8V, 0.8 5.0 mA IO = 0.75mA Isolation Resistance RI-O VI-O = 1kVDC 1011 Ω Isolation Capacitance CI-O V = 0V, f = 1MHz 0.7 pF Propagation Delay Time tPHL VCC = 15V, IF =10mA, 180 500 ns (H  L)*2 RL =20kΩ, CL = 100pF Propagation Delay Time tPLH VTHHL = 1.5V, VTHLH = 2.0V 420 750 ns (L  H)*2 Propagation Delay Difference tPLH-tPHL -200 240 650 ns Pulse Width Distortion |tPHL-tPLH| 240 650 ns (PWD)*2 Common Mode CMH TA = 25°C, IF = 0mA, 50 kV/µs Transient Immunity at High VCM = 1.5kV, RL=20kΩ Level Output*3 CL = 100pF, VO >3.0V Common Mode CML TA = 25°C, IF =10mA, 50 kV/µs Transient Immunity at Low VCM = 1.5kV, RL=20kΩ Level Output*3 CL =100pF, VO<1.0V Notes*: 1. Typical values at TA = 25°C. 2. Test circuit for propagation delay time 3. Test circuit for common mode transient immunity R08DS0187EJ0100 Rev.1.00 Page 5 of 15 Nov 11,2019
