Datasheet AL8862Q (Diodes) - 2
ПроизводительDiodes
ОписаниеAutomotive Grade 55V 1A Step-Down Converter
Страниц / Страница16 / 2 — AL8862Q. Typical Applications Circuit. Pin Descriptions. Pin Number. Pin …
Формат / Размер файлаPDF / 995 Кб
AL8862Q. Typical Applications Circuit. Pin Descriptions. Pin Number. Pin Name. Function. Functional Block Diagram. www.diodes.com
AL8862Q Typical Applications Circuit Pin Descriptions Pin Number Pin Name Function Functional Block Diagram www.diodes.com
33 предложений от 12 поставщиков
Микросхемы Драйверов Светодиодов
AL8862QSP-13
Diodes
22 ₽
727GS
AL8862QSP-13
Diodes
от 31 ₽
AL8862QSP-13
Diodes
от 85 ₽
Hi-Tech Circuit Group
AL8862QSP-13
Diodes
V R IN: 5 to 55V SET VIN SET CTRL C1 AL8862Q D1 FAULT GND SW L1
Set Nominal Output Current Pin. Connect resistor R 1 SET SET from this pin to VIN to define nominal average output current. 2,7 GND Ground of IC 3 FAULT FAULT Indication. Asserted Low to report faulty conditions. Needs an external pull-up resistor. Input voltage (5V to 55V). Decouple to ground with 10μF or higher X7R ceramic capacitor close to 4 VIN device. 5,6 SW Switch Pin. Connect inductor/freewheeling diode here, minimizing track length at this pin to reduce EMI. Multi-function On/Off and brightness control pin: Leave floating for normal operation. Drive to voltage below 0.3V to turn off output current Drive with DC voltage (0.4V < VSET < 2.5V) to adjust output current from 10% to 100% of IOUT_NOM 8 CTRL Drive with an analog voltage >2.6V output current will be 100% of IOUT_NOM A PWM signal (Low level <0.3V, High level >2.6V, transition times less than 1s) allows the output current to be adjusted over a wide range up to 100% Connect a capacitor from this pin to ground to increase soft-start time. (Default soft-start time = 0.1ms. Additional soft-start time is approximately 1.5ms/1nF) EP EP Exposed pad/TAB connects to GND and thermal mass for enhanced thermal impedance.
SET FAULT SW 1 3 4 OTP 5, 6 VIN SW Open Fault VDD Generator Current I Monitor LIMITER Logic OCP Comp BG & Ref Hysteresis PWM Logic Driver Reference Control 8 PWM/DC CTRL OTP Dimming OTP PWM 2 7 GND GND AL8862Q 2 of 16 December 2019 Document number: DS42199 Rev. 3 - 2
www.diodes.com
© Diodes Incorporated
