Datasheet BCR430UW6 (Diodes) - 3
ПроизводительDiodes
ОписаниеLow Dropout Voltage Linear LED Driver Ic In SOT26
Страниц / Страница9 / 3 — BCR430UW6. Absolute Maximum Ratings. Parameter. Symbol. Min. Max. Unit. …
Формат / Размер файлаPDF / 682 Кб
BCR430UW6. Absolute Maximum Ratings. Parameter. Symbol. Min. Max. Unit. Recommended Operating Conditions. Thermal Characteristics
BCR430UW6 Absolute Maximum Ratings Parameter Symbol Min Max Unit Recommended Operating Conditions Thermal Characteristics
34 предложений от 12 поставщиков
Микросхемы Драйверов Светодиодов
BCR430UW6-7
Diodes
от 3.61 ₽
Зенер
Россия и страны ТС
BCR430UW6-7
от 9.50 ₽
Microfind
BCR430UW6-7
Diodes
17 ₽
BCR430UW6-7
Diodes
от 23 ₽
(Voltage relative to GND, @TA = +25°C, unless otherwise specified.)
Supply Voltage VS -0.5 45 V Output Current IOUT 0 100 mA Output Voltage VOUT -0.5 42 V REXT Current IREXT 0 0.3 mA REXT Voltage VREXT -0.5 5 V
Recommended Operating Conditions Parameter Symbol Min Max Unit
Supply Voltage VS 5 42 V OUT Pin Voltage Range VOUT 0.5 40 V Output Current (Note 5) IOUT 5 100 mA Ambient Temperature Range (Notes 5 & 6) TA -40 +125 °C Normal Operation Junction Temperature Range TJ -40 +125 °C (Note 6)
(@TA = +25°C, unless otherwise specified.)
Characteristic Symbol Value Unit
(Note 7) 922 Power Dissipation PD mW (Note 8) 993 (Note 7) 136 Thermal Resistance, Junction to Ambient RθJA (Note 8) 126 °C/W Thermal Resistance, Junction to Lead (Note 9) RθJL 88.5 Operating Junction Temperature TJ -40 +150 °C Recommended Storage Temperature TS -55 +165 °C
ESD Ratings
(Note 10)
Characteristics Symbols Value Unit JEDEC Class
Electrostatic Discharge – Human Body Model HBM 2000 V 2 Charge Device Model CDM 1000 V C5 Notes: 5. Subject to power dissipation and junction temperature not exceeding +125°C; beyond TJ = +100°C the LED current may start to fold back reducing the temperature of both the IC and LEDs. 6. Device will operate with its junction temperature at +125°C, however at this junction temperature the LED current will have been automatically reduced (folded back) from designed (room temperature/+25°C) level. 7. For a device mounted on MRP FR4-PCB; device is measured under still air conditions whilst operating in a steady-state. 8. Same as Note 7, except the device is mounted on 25mm  25mm 2oz copper. 9. RθJL = Thermal resistance from junction to solder-point (at the end of the OUT leads). 10. Refer to JEDEC specification JESD22-A114 and JESD22-A115. BCR430UW6 3 of 9 October 2019 Datasheet number: DS42214 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated
