Datasheet 2ED2181 (4) S06F (J) (Infineon) - 5
ПроизводительInfineon
Описание650 V high-side and low-side gate driver with integrated bootstrap diode
Страниц / Страница24 / 5 — HIN. LIN. VSS. COM. VCC
Версия02_01
Формат / Размер файлаPDF / 926 Кб
HIN LIN VSS COM VCC
47 предложений от 15 поставщиков
Gate Driver, 1 канал(-ов), Высокая Сторона и Низкая Сторона, IGBT, MOSFET, 8 вывод(-ов), SOIC
Зенер
Россия и страны ТС
2ED2181S06FXUMA1
от 74 ₽
ЧипСити
2ED2181S06FXUMA1
Infineon
84 ₽
2ED2181S06FXUMA1
160 ₽
2ED2181S06FXUMA1
Infineon
от 255 ₽
2ED2181 (4) S06F (J) 650 V high-side and low-side driver with integrated bootstrap diode 3 Pin configuration and functionality 3.1 Pin configuration 1
HIN
14 1
HIN VB
8 2
LIN VB
13 2
LIN HO
7 3
VSS HO
12 3
COM VS
6 4 11
VS
4
LO VCC
5 5
COM
10 6
LO
9 7
VCC
8 8-Lead DSO-8 (150 mil) 14-Lead DSO-14 (150 mil) 2ED2181S06F 2ED21814S06J Figure 3 2ED2181(4)S06F(J) pin assignments (top view) 3.2 Pin functionality Table 2 Symbol Description HIN Logic input for high side gate driver output (HO), in phase with HO LIN Logic input for low side gate driver output (LO), in phase with LO VSS Logic ground ( 2ED21814S06J only) COM Low-side gate drive return LO Low-side driver output VCC Low-side and logic supply voltage VS High voltage floating supply return HO High-side driver output VB High-side gate drive floating supply Datasheet 5 of 24 V 2.10 www.infineon.com/soi 2019-09-12 Document Outline Features Product summary Product validation Description 1 Table of contents 2 Block diagram 3 Pin configuration and functionality 3.1 Pin configuration 3.2 Pin functionality 4 Electrical parameters 4.1 Absolute maximum ratings 4.2 Recommended operating conditions 4.3 Static electrical characteristics 4.4 Dynamic electrical characteristics 5 Application information and additional details 5.1 IGBT / MOSFET gate drive 5.2 Switching and timing relationships 5.3 Matched propagation delays 5.4 Input logic compatibility 5.5 Undervoltage lockout 5.6 Bootstrap diode 5.7 Calculating the bootstrap capacitance CBS 5.8 Tolerant to negative tranisents on input pins 5.9 Negative voltage transient tolerance of VS pin 5.10 NTSOA – Negative Transient Safe Operating Area 5.11 Higher headroom for input to output signal transmission with logic operation upto -11 V 5.12 Maximum switching frequency 5.13 PCB layout tips 6 Qualification information0F 7 Related products 8 Package details 9 Part marking information 10 Additional documentation and resources 10.1 Infineon online forum resources 11 Revision history
