Datasheet AD8206 (Analog Devices) - 3
ОписаниеHigh Common-Mode Voltage, Bidirectional Current Shunt Amplifier
Страниц / Страница13 / 3 — Data Sheet. AD8206. SPECIFICATIONS. Table 1. AD8206 SO. Parameter. Test …
ВерсияC
Формат / Размер файлаPDF / 363 Кб
Data Sheet. AD8206. SPECIFICATIONS. Table 1. AD8206 SO. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD8206 SPECIFICATIONS Table 1 AD8206 SO Parameter Test Conditions/Comments Min Typ Max Unit
24 предложений от 14 поставщиков
Зенер
Россия и страны ТС
AD8206WHRZ
от 295 ₽
AD8206WHRZ-RL
340 ₽
AD8206WHRZ-RL
от 670 ₽
AD8206WHRZ
link to page 4 link to page 4 link to page 4 link to page 4
TA = operating temperature range, VS = 5 V, unless otherwise noted.
Table 1. AD8206 SO IC Parameter Test Conditions/Comments Min Typ Max Unit
GAIN Initial 20 V/V Accuracy VO ≥ 0.1 V dc, 25°C ±1 % Accuracy Over Temperature Specified temperature range ±1.2 % Gain vs. Temperature 30 ppm/°C VOLTAGE OFFSET Offset Voltage (RTI) 25°C ±2 mV Over Temperature (RTI) Specified temperature range ±4.5 mV Offset Drift 15 µV/°C INPUT Input Impedance Differential 400 kΩ Common Mode 200 kΩ Input Voltage Range Common mode, continuous −2 +65 V Differential1 250 mV Common-Mode Rejection 25°C, f = dc to 20 kHz2 76 86 dB Operating temperature range, 76 80 dB f = dc to 20 kHz2 OUTPUT Output Voltage Range AD8206YRZ, RL = 25 kΩ 0.08 4.7 V AD8206WYRZ, RL = 25 kΩ 0.08 4.7 V AD8206WHRZ, RL = 25 kΩ 0.08 4.65 V Output Resistance 2 Ω DYNAMIC RESPONSE Small Signal −3 dB Bandwidth 100 kHz Slew Rate 0.5 V/µs NOISE 0.1 Hz to 10 Hz, RTI 20 µV p-p Spectral Density, 1 kHz, RTI 0.5 µV/√Hz OFFSET ADJUSTMENT Ratiometric Accuracy3 Divider to supplies 0.497 0.503 V/V Accuracy, RTO Voltage applied to VREF1 and VREF2 in parallel ±2 mV/V Output Offset Adjustment Range AD8206YRZ, VS = 5 V 0.08 4.7 V AD8206WYRZ, VS = 5 V 0.08 4.7 V AD8206WHRZ, VS = 5 V 0.08 4.65 V VREF Input Voltage Range 0.0 VS V VREF Divider Resistor Values 24 32 40 kΩ Rev. C | Page 3 of 13 Document Outline FEATURES EXCELLENT AC AND DC PERFORMANCE APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION OUTPUT OFFSET ADJUSTMENT UNIDIRECTIONAL OPERATION GROUND REFERENCED OUTPUT V+ REFERENCED OUTPUT BIDIRECTIONAL OPERATION EXTERNAL REFERENCED OUTPUT SPLITTING THE SUPPLY SPLITTING AN EXTERNAL REFERENCE APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSE WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSE WITH A HIGH-SIDE SWITCH OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
