Линейка продуктов KEEN SIDE
Datasheet AD8206 (Analog Devices) - 7
ОписаниеHigh Common-Mode Voltage, Bidirectional Current Shunt Amplifier
Страниц / Страница13 / 7 — Data Sheet. AD8206. TYPICAL PERFORMANCE CHARACTERISTICS. 500. 400. 300. …
ВерсияC
Формат / Размер файлаPDF / 363 Кб
Data Sheet. AD8206. TYPICAL PERFORMANCE CHARACTERISTICS. 500. 400. 300. 200. 100. TYPICAL. IN SOIC. IN (d. OSIV. –100. –200. TYPICAL DIE. –300. –400
Data Sheet AD8206 TYPICAL PERFORMANCE CHARACTERISTICS 500 400 300 200 100 TYPICAL IN SOIC IN (d OSIV –100 –200 TYPICAL DIE –300 –400
38 предложений от 17 поставщиков
AD8206YRZ-REEL
139 ₽
AD8206YRZ-REEL7
395 ₽
AD8206YRZ-REEL
LifeElectronics
AD8206YRZREEL7
Data Sheet AD8206 TYPICAL PERFORMANCE CHARACTERISTICS 500 40 400 35 300 30 200 100 TYPICAL 25 IN SOIC
V) B) ( 0 20 IN (d OSIV A –100 G 15 –200 TYPICAL DIE 10 –300 –400 5
036
–500
04953-
0
04953-007
–40 –20 0 20 40 60 80 100 120 140 10 100 1k 10k 100k 1M TEMPERATURE ( C) FREQUENCY (Hz)
Figure 4. Typical Offset Drift Figure 7. Typical Small Signal Bandwidth (VOUT = 200 mV p-p)
120 110 100 90 200mV/DIV 80 70 60 CMR (dB) 50 40 30 20 1V/DIV 10
023
0
04953-004 04953-
10 100 1k 10k 100k 1M 10M 40
s/DIV FREQUENCY (Hz)
Figure 5. CMR vs. Frequency Figure 8. Rise/Fall Time
12000 10000 250mV/DIV 8000 6000 ) TYPICAL 4000 m IN SOIC p p 2000 0 RROR ( –2000 TYPICAL 2V/DIV –4000 DIE GAIN E –6000 –8000 –10000
035 025
–12000
04953-
04953-
TEMPERATURE ( C) 2
s/DIV
Figure 6. Gain Drift Figure 9. Differential Overload Recovery (Falling) Rev. C | Page 7 of 13 Document Outline FEATURES EXCELLENT AC AND DC PERFORMANCE APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION OUTPUT OFFSET ADJUSTMENT UNIDIRECTIONAL OPERATION GROUND REFERENCED OUTPUT V+ REFERENCED OUTPUT BIDIRECTIONAL OPERATION EXTERNAL REFERENCED OUTPUT SPLITTING THE SUPPLY SPLITTING AN EXTERNAL REFERENCE APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSE WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSE WITH A HIGH-SIDE SWITCH OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
