Datasheet MMBT4401 (Diodes) - 2
ПроизводительDiodes
Описание40V NPN SMALL SIGNAL TRANSISTOR IN SOT23
Страниц / Страница7 / 2 — MMBT4401. Absolute Maximum Ratings. Thermal Characteristics. …
Формат / Размер файлаPDF / 264 Кб
MMBT4401. Absolute Maximum Ratings. Thermal Characteristics. Characteristic Symbol. Value. Unit. ESD Ratings. JEDEC. Class
MMBT4401 Absolute Maximum Ratings Thermal Characteristics Characteristic Symbol Value Unit ESD Ratings JEDEC Class
28 предложений от 13 поставщиков
MMBT4401-13-F
Diodes
от 0.30 ₽
Эиком
MMBT4401-13-F
Diodes
от 2.65 ₽
Зенер
Россия и страны ТС
MMBT4401-13-F
Diodes
5.30 ₽
727GS
MMBT4401-13-F
Diodes
20 957 ₽
(@TA = +25°C unless otherwise specified) Characteristic Symbol Value Unit Collector-Base Voltage VCBO 60 V Collector-Emitter Voltage VCEO 40 V Emitter-Base Voltage VEBO 6.0 V Collector Current IC 600 mA Peak Collector Current ICM 1 A Peak Base Current IBM 200 mA
(Note 6) 310 Power Dissipation PD mW (Note 7) 350 (Note 6) 403 Thermal Resistance, Junction to Ambient RθJA C/W (Note 7) 357 Thermal Resistance, Junction to Leads (Note 8) RθJL 350 C/W Operating and Storage Temperature Range TJ,TSTG -55 to +150 C
ESD Ratings
(Note 9)
Characteristic Symbol Value Unit JEDEC Class
Electrostatic Discharge - Human Body Model ESD HBM 4,000 V 3A Electrostatic Discharge - Machine Model ESD MM 400 V C Notes: 6. For a device mounted on minimum recommended pad layout 1oz copper that is on a single-sided FR4 PCB; device is measured under still air conditions whilst operating in a steady-state. 7. Same as note (6), except the device is mounted on 15 mm x 15mm 1oz copper. 8. Thermal resistance from junction to solder-point (at the end of the leads). 9. Refer to JEDEC specification JESD22-A114 and JESD22-A115. MMBT4401 2 of 7 November 2013 Document Number: DS30039 Rev. 17 - 2
www.diodes.com
© Diodes Incorporated
