Datasheet ADP5076 (Analog Devices) - 9 Производитель Analog Devices Описание 2 A/1.2 A DC-to-DC Switching Regulator with Independent Positive and Negative Outputs Страниц / Страница 23 / 9 — Data Sheet. ADP5076. 100. A = +125°C. TA = +25°C. A = +25°C. A = –40°C. … Версия A Формат / Размер файла PDF / 725 Кб Язык документа английский
Data Sheet. ADP5076. 100. A = +125°C. TA = +25°C. A = +25°C. A = –40°C. (% 60. N 50. IEN. F 40. 0.001. 0.01. 0.1. LOAD CURRENT (A). 0.5. 0.4. 0.3. (%). 0.2
Скачать PDF
30 предложений от 11 поставщиков
V+/V- SW REGULATOR WITH 2A/1.2A. Switching Regulator IC Output. PMIC - Voltage Regulators - DC DC Switching Regulators
ADP5076ACBZ-R7 Analog Devices от 314 ₽ КупитьADP5076ACBZ-R7 474 ₽ КупитьADP5076ACBZ-R7 Analog Devices 503 ₽ КупитьADP5076ACBZ-R7 от 600 ₽ Купить
Модельный ряд для этого даташита Текстовая версия документа Data Sheet ADP5076 100 100 T T A = +125°C A = +125°C T 90 TA = +25°C 90 A = +25°C T T A = –40°C A = –40°C 80 80 70 70 ) ) (% 60 (% 60 Y Y C C N 50 50 IE IEN IC IC F 40 F 40 EF EF 30 30 20 20 10 10 0 0 1180.001 0.01 0.1 1 1150.001 0.01 0.1 1 2-LOAD CURRENT (A) LOAD CURRENT (A) 2040 20402- Figure 15. Boost Regulator Efficiency over Temperature, Figure 18. Inverting Regulator Efficiency over Temperature, VIN = 5 V, VPOS = 15 V, fSW = 1.2 MHz VIN = 5 V, VNEG = −15 V, fSW = 1.2 MHz0.5 0.5 0.4 0.4 0.3 (%) 0.3 (%) 0.2 INAL 0.2 M INAL 0.1 M 0.1 NO M NO 0 M RO O 0 F R N –0.1 F N –0.1 IO IO AT –0.2 AT –0.2 ARI RI V –0.3 A V –0.3 –0.4 V V NEG ACCURACY POS ACCURACY –0.4 V V REF ACCURACY FB1 ACCURACY VFB2 ACCURACY –0.5 52.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 –0.5 01 2-2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 018V 40IN (V) 20VIN (V) 20402- Figure 16. Boost Regulator Line Regulation, VPOS = 15 V, Figure 19. Inverting Regulator Line Regulation, VNEG = −15 V, fSW = 1.2 MHz, 15 mA Load, TA = 25°C fSW = 1.2 MHz, 15 mA Load, TA = 25°C0.5 0.5 ) ) (% 1.2MHz 0.4 (% E 0.4 E 2.4MHz G 0.3 0.3 LTAG LTA O V 0.2 0.2 T VO UT P PU 0.1 T 0.1 UT U O O L 0 L 0 A INA IN M –0.1 –0.1 O OM N N –0.2 –0.2 IN IN N N –0.3 IO –0.3 IO T T A IA –0.4 1.2MHz R –0.4 ARI A V 2.4MHz V –0.5 –0.5 0 0.05 0.10 0.15 0.20 0.25 1170 0.05 0.10 0.15 0.20 -120LOAD CURRENT (A) LOAD CURRENT (A) 20402 20402- Figure 17. Boost Regulator Load Regulation, VIN = 5 V, VPOS = 15 V Figure 20. Inverting Regulator Load Regulation, VIN = +5 V, VNEG = −15 V Rev. A | Page 9 of 23 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION PULSE WIDTH MODULATION (PWM) MODE PULSE SKIP MODULATION MODE UVLO OSCILLATOR AND SYNCHRONIZATION INTERNAL REGULATOR PRECISION ENABLING SOFT START SLEW RATE CONTROL CURRENT-LIMIT PROTECTION OVERVOLTAGE PROTECTION THERMAL SHUTDOWN STARTUP SEQUENCE APPLICATIONS INFORMATION COMPONENT SELECTION Feedback Resistors OUTPUT CAPACITORS Input Capacitor VREF Capacitor Soft Start Resistor Diodes Inductor Selection for the Boost Regulator Inductor Selection for the Inverting Regulator LOOP COMPENSATION Boost Regulator Inverting Regulator COMMON APPLICATIONS LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
