Datasheet TLP2363 (Toshiba) - 4
ПроизводительToshiba
ОписаниеPhotocouplers Infrared LED & Photo IC
Страниц / Страница18 / 4 — TLP2363. 8. Electrical. Characteristics. (Note). (Unless. otherwise. …
Формат / Размер файлаPDF / 856 Кб
TLP2363. 8. Electrical. Characteristics. (Note). (Unless. otherwise. specified,. Ta. =. -40. to. 105. ,. VCC. =. 2.7. to. 5.5. V). Test. Characteristics. Symbol
TLP2363 8 Electrical Characteristics (Note) (Unless otherwise specified, Ta = -40 to 105 , VCC = 2.7 to 5.5 V) Test Characteristics Symbol
22 предложений от 7 поставщиков
HIGH SPEED PHOTOCOUPLER; 10MBD;
Элитан
TLP2363(V4
Toshiba
63 ₽
TLP2363(V4-TPR,E
Toshiba
от 71 ₽
Эиком
TLP2363(V4-TPR,E
Toshiba
от 73 ₽
TLP2363(V4-TPR,E
86 ₽
TLP2363 8. Electrical Characteristics (Note) (Unless otherwise specified, Ta = -40 to 105 , VCC = 2.7 to 5.5 V) Test Characteristics Symbol Note Test Condition Min Typ. Max Unit Circuit Input forward voltage VF - IF = 2.6 mA, Ta = 25 1.35 1.5 1.65 V Input forward voltage ∆VF/∆Ta - IF = 2.6 mA  -1.54  mV/ temperature coefficient Input reverse current IR - VR = 5 V, Ta = 25   10 µA Input capacitance Ct - V = 0 V, f = 1 MHz, Ta = 25  17  pF High-level output current IOH Fig. VF = 0.8 V, VO = 5.5 V,   50 µA 11.1.1 VCC = 5.5 V VF = 0.8 V, VO = 5.5 V,   10 VCC = 5.5 V, Ta = 25 Low-level output voltage VOL Fig. IF = 5 mA,  0.33 0.6 V 11.1.2 IO = 13 mA (Sinking) Low-level supply current ICCL Fig. IF = 5 mA  1.8 4.0 mA 11.1.3 High-level supply current ICCH Fig. IF = 0 mA  1.6 4.0 11.1.4 Threshold input current (H/L) IFHL - IO = 13 mA (Sinking),  1.25 5.0 VO < 0.6 V VCC = 3.3 V, RL = 1 kΩ, 0.3 0.9 2.4 VO < 0.6 V Note: All typical values are at VCC = 5 V, Ta = 25 . 9. Isolation Characteristics (Unless otherwise specified, Ta = 25 ) Characteristics Symbol Note Test Condition Min Typ. Max Unit Total capacitance (input to output) CS (Note 1) VS = 0 V, f = 1 MHz  0.8  pF Isolation resistance RS (Note 1) VS = 500 V, R.H. ≤ 60 % 1 × 1012 1014  Ω Isolation voltage BVS (Note 1) AC, 60 s 3750   Vrms Note 1: This device is considered as a two-terminal device: Pins 1 and 3 are shorted together, and pins 4, 5 and 6 are shorted together. ©2019 4 2019-11-07 Toshiba Electronic Devices & Storage Corporation Rev.1.0
