Datasheet PT7C4563BQ (Diodes) - 2
ПроизводительDiodes
ОписаниеAutomotive Grade Real-time Clock
Страниц / Страница19 / 2 — PT7C4563BQ. Pin Configuration. Pin Description. Pin#. Pin. Type. …
PT7C4563BQ. Pin Configuration. Pin Description. Pin#. Pin. Type. Description. Oscillator Circuit Input. Oscillator Circuit Output
PT7C4563BQ Pin Configuration Pin Description Pin# Pin Type Description Oscillator Circuit Input Oscillator Circuit Output
28 предложений от 10 поставщиков
IC RTC CLK/CALENDAR I2C 8SOIC
PT7C4563BQ1WEX
Diodes
от 13 ₽
PT7C4563BQ1WEX
Diodes
98 ₽
PT7C4563BQ1WEX
Diodes
от 114 ₽
Hi-Tech Circuit Group
PT7C4563BQ1WEX
Diodes
SOIC-8 1 X1 VCC 8 2 X2 SQW 7 3 INT SCL 6 4 GND SDA 5
1 X1 I
Together with X2, the 32.768kHz crystal is connected between them. 2 X2 O
Oscillator Circuit Output.
Together with X1, the 32.768kHz crystal is connected between them. 3 INT O
Interrupt Output.
Open drain, active low. 4 GND P
Ground.
5 SDA I/O
Serial Data Input/Output.
SDA is the input/output pin for the 2-wire serial interface. The SDA pin is open-drain output and requires an external pull-up resistor. 6 SCL I
Serial Clock Input.
SCL is used to synchronize data movement on the I2C serial interface. 7 SQW O
Clock Output.
Open drain. Four frequencies selectable: 32.768k, 1.024k, 32, 1Hz when SQWE bit is set to 1. 8 VCC P
Power.
PT7C4563BQ
www.diodes.com
July 2019 Document Number DS41477 Rev 2-2 2 © Diodes Incorporated Document Outline Features Description Pin Configuration Pin Description Function Block Maximum Ratings Recommended Operating Conditions DC Electrical Characteristics AC Electrical Characteristics Recommended Layout for Crystal Cpar = all parasitical capacitor between X1 and X2 Crystal Specifications Function Description Overview of Functions Registers Control and Status Register Time Counter Days of the Week Counter Calendar Counter Communication I2C Bus Interface Overview of I2C Bus System Configuration Starting and Stopping I2C Bus Communications Slave Address Part Marking Packaging Mechanical W (SOIC-8)
