Datasheet VCNL36826S (Vishay) - 2
ПроизводительVishay
ОписаниеProximity Sensor With Interrupt, VCSEL, and I²C Interface
Страниц / Страница16 / 2 — VCNL36826S. ORDERING INFORMATION ORDERING CODE. PACKAGING. VOLUME (1). …
Формат / Размер файлаPDF / 196 Кб
VCNL36826S. ORDERING INFORMATION ORDERING CODE. PACKAGING. VOLUME (1). REMARKS. Note. ABSOLUTE MAXIMUM RATINGS. PARAMETER
VCNL36826S ORDERING INFORMATION ORDERING CODE PACKAGING VOLUME (1) REMARKS Note ABSOLUTE MAXIMUM RATINGS PARAMETER
47 предложений от 14 поставщиков
Бесконтактный датчик, I2C, 200 мм, SMD, 8 вывод(-ов), 2.62 В, 3.6 В
VCNL36826S
от 33 ₽
VCNL36826S
204 ₽
VCNL36826S
236 ₽
VCNL36826S
от 356 ₽
VCNL36826S
www.vishay.com Vishay Semiconductors
VCNL36826S Tape and reel MOQ: 3000 pcs, 3000 pcs/reel 2.55 mm x 2.05 mm x 1.0 mm
Note
(1) MOQ: minimum order quantity
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. MAX. UNIT
Supply voltage VDD -0.3 3.8 V Operation temperature range Tamb -40 +85 °C Storage temperature range Tstg -40 +100 °C
BASIC CHARACTERISTICS
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Supply voltage (2) VDD 2.62 - 3.6 V Supply current Excluding VCSEL driving IDD 100 200 300 μA Light condition = dark; Shutdown current I V DD (SD) - 1 - μA DD = 3.3 V, Tamb = 25 °C PS dark (1) - - 2 step I2C supply voltage VPULL UP 1.65 - - V I2C signal input, logic high VDD = 3.3 V VIH 1.26 - - V I2C signal input, logic low VDD = 3.3 V VIL - - 0.73 V Peak wavelength of VCSEL IF = 10 mA λp(VCSEL) - 940 - nm PS view angle (3) - 60 - ° VCSEL driving current - - 20 mA
Notes
(1) PS_IT = 4T; IVCSEL = 20 mA; PS_HG = 1 (2) Based on VCSEL current setting, VDD min. voltage need adjust, example as below VCSEL current setting 6 mA 8 mA 10 mA 12 mA 14 mA 16 mA 18 mA 20 mA Min. VDD 2.62 V 2.74 V 2.84 V 2.94 V 3.03 V 3.11 V 3.19 V 3.29 V (3) Shows total view angle of X axis (X axis: +10° to -50°; Y axis: ± 45°) Y X Rev. 1.0, 29-Jan-2020
2
Document Number: 84964 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
