Datasheet L6983 (STMicroelectronics) - 5
| Производитель | STMicroelectronics |
| Описание | 38 V 3A synchronous step-down converter with 17uA quiescent current |
| Страниц / Страница | 63 / 5 — L6983. Pin configuration. Pin. Symbol. Function. DS13116. Rev 1. page 5/63 |
| Формат / Размер файла | PDF / 5.1 Мб |
23 предложений от 14 поставщиков 38 V 3A SYNCHRONOUS STEP-DOWN CO. Switching Regulator IC Output. PMIC - Voltage Regulators - DC DC Switching Regulators |
| L6983C33QTR STMicroelectronics | 217 ₽ | |
| L6983C33QTR STMicroelectronics | 228 ₽ | |
| L6983C33QTR STMicroelectronics | 283 ₽ | |
| L6983C33QTR STMicroelectronics | по запросу | |
L6983 Pin configuration Pin Symbol Function
12 VIN DC input voltage. 13 PGND Power ground. 14 SW Switching node. 15 SW Switching node. 16 PGND Power ground. - Exposed PAD Exposed pad must be connected to AGND and PGND.
DS13116
Rev 1 page 5/63
Document Outline 1 Diagram 2 Pin configuration 3 Typical application circuit 4 Absolute maximum ratings 4.1 ESD protection 4.2 Thermal characteristics 5 Electrical characteristics 5.1 Frequency selection table 6 Functional description 6.1 Enable 6.2 Soft-start 6.3 Undervoltage lockout 6.4 Light-load operation 6.4.1 Low consumption mode (LCM) 6.4.2 Low noise mode (LNM) 6.4.3 Efficiency for low consumption mode and low noise mode part number 6.4.4 Load regulation for low consumption mode and Low noise mode part number 6.5 Switch-over feature 6.6 Spread spectrum 6.7 Overvoltage protection 6.8 Overcurrent protection 6.9 Thermal shutdown 6.10 Power Good 7 Closing the loop 7.1 GCO(s) control to output transfer function 7.2 Error amplifier compensation network 7.3 Voltage divider 8 Application notes 8.1 Programmable power up threshold 8.2 External synchronization (available for low noise mode only) 8.3 Output voltage adjustment 8.4 Switching frequency 8.5 Design of the power components 8.5.1 Input capacitor selection 8.5.2 Inductor selection 8.5.3 Output capacitor selection 9 Application board 10 Efficiency curves 11 Thermal dissipation 12 Package information 12.1 QFN16 (3x3 mm) package information 13 Ordering information Revision history
