Datasheet CCE4503 (Dialog Semiconductor) - 5
ПроизводительDialog Semiconductor
ОписаниеIO-Link Device
Страниц / Страница16 / 5 — CCE4503. IO-Link Device IC. Pinout. igure 3: DFN10 Pinout Diagram (Top …
Формат / Размер файлаPDF / 619 Кб
CCE4503. IO-Link Device IC. Pinout. igure 3: DFN10 Pinout Diagram (Top View). Table 1: Pin Description. Pin No. Pin Name. Type. Reset
CCE4503 IO-Link Device IC Pinout igure 3: DFN10 Pinout Diagram (Top View) Table 1: Pin Description Pin No Pin Name Type Reset
link to page 6
CCE4503 IO-Link Device IC 2 Pinout
P U W MI N +L CQ -L LI 10 9 8 7 6 Thermal Pad 1 2 3 4 5 D R D D N D R X X E V E R T X N T
igure 3: DFN10 Pinout Diagram (Top View) Table 1: Pin Description Pin No. Pin Name Type Reset Description (Table 2) State
1 VDD PWR 3.3V - 5V Supply Voltage Input / Output 2 NERR OD High-Z Error Output (Overcurrent detection, Undervoltage detection, Overtemperature detection 3 RXD DO Channel signal output 4 TXD DI, PU Channel signal input 5 TXEN DI, PD Channel driver enable 6 ILIM AI Current Limit configuration 7 L- PWR Ground supply (IO-Link) 8 CQ DIO IO-Link data 9 L+ PWR Positive supply (IO-Link) 10 NWUP OD High-Z Wake-up detection (Channel short detection) PAD Thermal Pad GND Thermal Pad, connect to VSS or leave open
Datasheet Revision 2.0 20.02.2020
CFR0011-120-00 5 of 16 © 2020 Dialog Semiconductor
