Datasheet ADAU1361 (Analog Devices) - 77
ОписаниеStereo, Low Power, 96 kHz, 24-Bit Audio Codec with Integrated PLL
Страниц / Страница80 / 77 — Data Sheet. ADAU1361. Binary Value. Volume Attenuation (dB). Table 74. …
ВерсияD
Data Sheet. ADAU1361. Binary Value. Volume Attenuation (dB). Table 74. R29 through R33 Volume Settings. Volume Setting (dB)
Data Sheet ADAU1361 Binary Value Volume Attenuation (dB) Table 74 R29 through R33 Volume Settings Volume Setting (dB)
27 предложений от 14 поставщиков
Audio Codec 2ADC / 2DAC 24bit 32-Pin LFCSP EP T/R
ADAU1361BCPZ-R7
от 769 ₽
ЭИК
ADAU1361BCPZ-R7
от 1 339 ₽
T-electron
ADAU1361BCPZR7
45 929 ₽
ADAU1361BCPZ-R7
Data Sheet ADAU1361 Binary Value Volume Attenuation (dB) Binary Value Volume Attenuation (dB)
11000010 −72.75 11110011 −91.125 11000011 −73.125 11110100 −91.5 11000100 −73.5 11110101 −91.875 11000101 −73.875 11110110 −92.25 11000110 −74.25 11110111 −92.625 11000111 −74.625 11111000 −93 11001000 −75 11111001 −93.375 11001001 −75.375 11111010 −93.75 11001010 −75.75 11111011 −94.125 11001011 −76.125 11111100 −94.5 11001100 −76.5 11111101 −94.875 11001101 −76.875 11111110 −95.25 11001110 −77.25 11111111 −95.625 11001111 −77.625 11010000 −78
11010001 −78.375
Binary Value Volume Setting (dB)
11010010 −78.75 000000 −57 11010011 −79.125 000001 −56 11010100 −79.5 000010 −55 11010101 −79.875 000011 −54 11010110 −80.25 000100 −53 11010111 −80.625 000101 −52 11011000 −81 000110 −51 11011001 −81.375 000111 −50 11011010 −81.75 001000 −49 11011011 −82.125 001001 −48 11011100 −82.5 001010 −47 11011101 −82.875 001011 −46 11011110 −83.25 001100 −45 11011111 −83.625 001101 −44 11100000 −84 001110 −43 11100001 −84.375 001111 −42 11100010 −84.75 010000 −41 11100011 −85.125 010001 −40 11100100 −85.5 010010 −39 11100101 −85.875 010011 −38 11100110 −86.25 010100 −37 11100111 −86.625 010101 −36 11101000 −87 010110 −35 11101001 −87.375 010111 −34 11101010 −87.75 011000 −33 11101011 −88.125 011001 −32 11101100 −88.5 011010 −31 11101101 −88.875 011011 −30 11101110 −89.25 011100 −29 11101111 −89.625 011101 −28 11110000 −90 011110 −27 11110001 −90.375 011111 −26 11110010 −90.75 100000 −25 Rev. D | Page 77 of 80 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Analog Performance Specifications Power Supply Specifications Typical Current Consumption Typical Power Management Measurements Digital Filters Digital Input/Output Specifications Digital Timing Specifications Digital Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics System Block Diagrams Theory of Operation Startup, Initialization, and Power Power-Up Sequence Power Reduction Modes Digital Power Supply Input/Output Power Supply Clock Generation and Management Case 1: PLL Is Bypassed Case 2: PLL Is Used PLL Lock Acquisition Clocking and Sampling Rates Core Clock Sampling Rates PLL Integer Mode Fractional Mode Record Signal Path Input Signal Paths Analog Microphone Inputs Analog Line Inputs Digital Microphone Input Microphone Bias Analog-to-Digital Converters ADC Full-Scale Level Digital ADC Volume Control High-Pass Filter Automatic Level Control (ALC) ALC Parameters Noise Gate Function Playback Signal Path Output Signal Paths Routing Flexibility Headphone Output Capless Headphone Configuration Headphone Output Power-Up/Power-Down Sequencing Ground-Centered Headphone Configuration Jack Detection Pop-and-Click Suppression Line Outputs Control Ports Burst Mode Writing and Reading I2C Port Addressing I2C Read and Write Operations SPI Port Chip Address R/ Subaddress Data Bytes Serial Data Input/Output Ports Applications Information Power Supply Bypass Capacitors GSM Noise Filter Grounding Exposed Pad PCB Design Control Registers Control Register Details R0: Clock Control, 16,384 (0x4000) R1: PLL Control, 16,386 (0x4002) R2: Digital Microphone/Jack Detection Control, 16,392 (0x4008) R3: Record Power Management, 16,393 (0x4009) R4: Record Mixer Left (Mixer 1) Control 0, 16,394 (0x400A) R5: Record Mixer Left (Mixer 1) Control 1, 16,395 (0x400B) R6: Record Mixer Right (Mixer 2) Control 0, 16,396 (0x400C) R7: Record Mixer Right (Mixer 2) Control 1, 16,397 (0x400D) R8: Left Differential Input Volume Control, 16,398 (0x400E) R9: Right Differential Input Volume Control, 16,399 (0x400F) R10: Record Microphone Bias Control, 16,400 (0x4010) R11: ALC Control 0, 16,401 (0x4011) R12: ALC Control 1, 16,402 (0x4012) R13: ALC Control 2, 16,403 (0x4013) R14: ALC Control 3, 16,404 (0x4014) R15: Serial Port Control 0, 16,405 (0x4015) R16: Serial Port Control 1, 16,406 (0x4016) R17: Converter Control 0, 16,407 (0x4017) R18: Converter Control 1, 16,408 (0x4018) R19: ADC Control, 16,409 (0x4019) R20: Left Input Digital Volume, 16,410 (0x401A) R21: Right Input Digital Volume, 16,411 (0x401B) R22: Playback Mixer Left (Mixer 3) Control 0, 16,412 (0x401C) R23: Playback Mixer Left (Mixer 3) Control 1, 16,413 (0x401D) R24: Playback Mixer Right (Mixer 4) Control 0, 16,414 (0x401E) R25: Playback Mixer Right (Mixer 4) Control 1, 16,415 (0x401F) R26: Playback L/R Mixer Left (Mixer 5) Line Output Control, 16,416 (0x4020) R27: Playback L/R Mixer Right (Mixer 6) Line Output Control, 16,417 (0x4021) R28: Playback L/R Mixer Mono Output (Mixer 7) Control, 16,418 (0x4022) R29: Playback Headphone Left Volume Control, 16,419 (0x4023) R30: Playback Headphone Right Volume Control, 16,420 (0x4024) R31: Playback Line Output Left Volume Control, 16,421 (0x4025) R32: Playback Line Output Right Volume Control, 16,422 (0x4026) R33: Playback Mono Output Control, 16,423 (0x4027) R34: Playback Pop/Click Suppression, 16,424 (0x4028) R35: Playback Power Management, 16,425 (0x4029) R36: DAC Control 0, 16,426 (0x402A) R37: DAC Control 1, 16,427 (0x402B) R38: DAC Control 2, 16,428 (0x402C) R39: Serial Port Pad Control, 16,429 (0x402D) R40: Control Port Pad Control 0, 16,431 (0x402F) R41: Control Port Pad Control 1, 16,432 (0x4030) R42: Jack Detect Pin Control, 16,433 (0x4031) R67: Dejitter Control, 16,438 (0x4036) Outline Dimensions Ordering Guide
