Datasheet SSM2604 (Analog Devices) - 7
ОписаниеLow Power Audio Codec
Страниц / Страница28 / 7 — Data Sheet. SSM2604. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table …
ВерсияB
Формат / Размер файлаPDF / 443 Кб
Data Sheet. SSM2604. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 7. Parameter. Rating. Table 8. Thermal Resistance
Data Sheet SSM2604 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 7 Parameter Rating Table 8 Thermal Resistance
32 предложений от 14 поставщиков
Интегральные микросхемы Интерфейс - Кодеки
SSM2604CPZ-REEL7
162 ₽
SSM2604CPZ-REEL7
625 ₽
SSM2604CPZ-REEL7
Hi-Tech Circuit Group
SSM2604CPZ-REEL7
At 25°C, unless otherwise noted.
THERMAL RESISTANCE Table 7.
θJA is specified for the worst-case conditions, that is, a device
Parameter Rating
soldered in a circuit board for surface-mount packages. Supply Voltage 3.6 V
Input Voltage VDD
Package Type θJA θJC-TOP θJC-BOTTOM Unit
Common-Mode Input Voltage VDD CP-20-8 52.7 31.4 1.52 °C/W Storage Temperature Range −65°C to +150°C Operating Temperature Range −40°C to +85°C Junction Temperature Range −65°C to +165°C
ESD CAUTION
Lead Temperature (Soldering, 60 sec) 300°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. B | Page 7 of 28 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Digital Filter Characteristics Timing Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Converter Filter Response Digital De-Emphasis Theory of Operation Digital Core ADC and DAC ADC High-Pass and DAC De-Emphasis Filters Analog Interface Signal Chain Stereo Line Inputs Bypass Path to Output Line Outputs Digital Audio Interface Recording Mode Playback Mode Digital Audio Data Sampling Rate Software Control Interface Control Register Sequencing Typical Application Circuits Register Map Register Map Details Left-Channel ADC Input Volume, Address 0x00 Right-Channel ADC Input Volume, Address 0x01 Analog Audio Path, Address 0x04 Digital Audio Path, Address 0x05 Power Management, Address 0x06 Power Consumption Digital Audio I/F, Address 0x07 Sampling Rate, Address 0x08 Active, Address 0x09 Software Reset, Address 0x0F Outline Dimensions Ordering Guide
