Datasheet PI6CG33402 (Diodes) - 9
ПроизводительDiodes
Описание3.3V Very-Low Power 4-Output PCIe Clock Generator With On-chip Termination
Страниц / Страница23 / 9 — PI6CG33402. HCSL Output Characteristics. Symbol. Parameters. Condition. …
PI6CG33402. HCSL Output Characteristics. Symbol. Parameters. Condition. Min. Typ. Max. Units. Note:. HCSL Output AC Characteristics
PI6CG33402 HCSL Output Characteristics Symbol Parameters Condition Min Typ Max Units Note: HCSL Output AC Characteristics
25 предложений от 11 поставщиков
Генераторы и Формироваетли Тактовых Сигналов
PI6CG33402CZHIEX-13R
Diodes
60 ₽
PI6CG33402CZHIEX
Diodes
206 ₽
Diodes
391 ₽
Hi-Tech Circuit Group
PI6CG33402CZHIEX
Diodes
A product Line of Diodes Incorporated
Temperature = TA; Supply voltages per normal operation conditions; See test circuits for the load conditions.
Symbol Parameters Condition Min. Typ. Max. Units
VOH Output Voltage High 1 Statistical measurement on single-ended 660 784 850 mV V signal using oscilloscope math function OL Output Voltage Low 1 -150 — 150 mV VOMAX Output Voltage Maximum 1 Measurement on single-ended signal using — 816 1150 mV V absolute value OMIN Output Voltage Minimum 1 -300 -42 — mV VOSWING Output Swing Voltage 1,2,3 Scope averaging off 300 1634 — mV VOC Output Cross Voltage 1,2,4 — 250 430 550 mV DVOC VOC Magnitude Change 1,2,5 — — 12 140 mV
Note:
1. At default SMBUS amplitude settings. 2. Guaranteed by design and characterization—not 100% tested in production. 3. Measured from differential waveform. 4. This one is defined as voltage where Q+ = Q- measured on a component test board and only applied to the differential rising edge. 5. The total variation of all Vcross measurements in any particular system. This is a subset of Vcross_min/max allowed.
fOUT Output Frequency — — 100 — MHz tRF Slew Rate 1,2,3 Scope averaging on fast setting 3 4 5 V/ns Scope averaging on slow setting 1.5 3.5 4.5 V/ns DtRF Slew Rate Matching 1,2,4 Scope averaging on — 3 — % tDC Duty Cycle 1,2 Measured differentially, PLL Mode 45 50 55 % tSKEW Output Skew 1,2 Averaging on, VT = 50% — 43 50 ps tjc-c Cycle-to-Cycle Jitter 1,2 — — 42 50 ps PI6CG33402 www.diodes.com May 2019 Document Number DS41073 Rev 3-2 9 Diodes Incorporated
