Datasheet PI6CB332000 (Diodes) - 9
ПроизводительDiodes
Описание20-Output PCIe G4 Clock Buffer With On-Chip Termination
Страниц / Страница21 / 9 — PI6CB332000. LVCMOS AC Electrical Characteristics. Symbol. Parameters. …
PI6CB332000. LVCMOS AC Electrical Characteristics. Symbol. Parameters. Conditions. Min. Typ. Max. Units. HCSL Input Characteristics(1)
PI6CB332000 LVCMOS AC Electrical Characteristics Symbol Parameters Conditions Min Typ Max Units HCSL Input Characteristics(1)
34 предложений от 12 поставщиков
Генераторы и Формироваетли Тактовых Сигналов
PI6CB332000ZDIEX
Diodes
от 85 ₽
PI6CB332000ZDIEX
Diodes
266 ₽
PI6CB332000ZDIEX
Diodes
514 ₽
PI6CB332000ZDIEX
Diodes
от 729 ₽
A product Line of Diodes Incorporated
Temperature = TA. Supply voltages per normal operation conditions. See test circuits for the load conditions.
Symbol Parameters Conditions Min. Typ. Max. Units
Q start after OE# assertion tOELAT Output Enable Latency 1 6 10 clocks Q stop after OE# deassertion tPDLAT PD# Deassertion Differential outputs enable after PD# deassertion — 200 300 µs
fIN Input Frequency — 1 100 200 MHz VIHDIF Diff. Input High Voltage (3) IN+, IN-, single-ended measurement 330 — 1150 mV VILDIF Diff. Input Low Voltage (3) IN+, IN-, single-ended measurement -300 0 300 mV VSWING Diff. Input Swing Voltage Peak-to-peak value (VIHDIF - VILDIF) 200 — — mV VCOM Common Mode Voltage — 0 — 900 mV tRF Diff. Input Slew Rate (2) — 0.7 — — V/ns IIN Diff. Input Leakage Current VIN = VDD, VIN = GND -5 — 5 µA tDC Diff. Input Duty Cycle Measured differentially 45 — 55 % tjc-c Diff. Input Cycle-to-Cycle Jitter Measured differentially — — 125 ps
Note:
1. Guaranteed by design and characterization—not 100% tested in production. 2. Slew rate measured through ±75mV window centered around differential zero. 3. The device can be driven by a single-ended clock by driving the true clock and biasing the complement clock input to the Vbias, where Vbias is (VIH-VIL)/2. PI6CB332000 www.diodes.com July 2019 Document Number DS41283 Rev 4-2 9 Diodes Incorporated
