Datasheet PPC (Cornell Dubilier) - 3
ПроизводительCornell Dubilier
ОписаниеType PPC, -55 ºC to + 125 ºC, Ultra-Thin Polymer Aluminum Electrolytic Capacitor
Страниц / Страница8 / 3 — Type PPC, -55 ºC to + 125 ºC, Ultra-Thin Polymer Aluminum Electrolytic …
Формат / Размер файлаPDF / 450 Кб
Type PPC, -55 ºC to + 125 ºC, Ultra-Thin Polymer Aluminum Electrolytic Capacitor. Outline Drawing. Ratings. Rated Volatge
Type PPC, -55 ºC to + 125 ºC, Ultra-Thin Polymer Aluminum Electrolytic Capacitor Outline Drawing Ratings Rated Volatge
6 предложений от 3 поставщиков
Алюминиевые Полимерные Конденсаторы
PPC203M6R3FG2SAA
Cornell Dubilier
7 199 ₽
PPC203M6R3FG2SAA
Cornell Dubilier
от 14 256 ₽
PPC203M6R3FG2SAA
Dimensions are in inches. Tolerance unless specified ±0.01”
Ratings Rated Volatge 120 Hz 20 KHz Max Max Surge 125 °C 105 °C 85 °C 25 °C 25 °C Ripple Ripple 25 °C Vdc Vdc Vdc Max ESR Max ESR 120 Hz 20 kHz Vdc Cap µF P/N
6.3 8 9 20000 PPC203M6R3FG2SAA 0.01 0.006 16 18 11 10 12 15 12000 PPC123M010FG2SAA 0.01 0.006 16 18 18 16 20 24 8000
PPCE1001 -55 ºC to +125 ºC
PPC802M016FG2SAA 0.01 0.006 16 18 28
Polymer-Aluminum Electrolytic Capacitor Recommended mounting Solder Type Part Numbering System TYPE CAP CAP TOL VDC WIDTH LENGTH TERM STYLE SPEC CH1 SPEC CH2
PPC 802 M 016 F G 2S A A
PPC 320
= 32 µF ±20%
6R3
= 6.3 Vdc See Outline Drawing
2S
- TWO SOLDER- ASSIGNED BY MFG ASSIGNED BY MFG
222
= 2200 µF
010
= 10 Vdc ABLE/BOLT / STUD
PPCE1001 -55 ºC to +125 ºC Polymer-Aluminum Electrolytic Capacitor 163
= 16000 µF
016
= 16 Vdc
Recommended mounting Solder Type Recommended Mounting Solder Type Stud Type
Restrict soldering temperatures to end of terminal only
Hardware: M6≈1/4-20 stud / bolt Copper flat washer, M6 washer with 12 mm (0.472") OD Stud Type
Precaution: Ensure proper terminal spacing and stud / bolt size.
Precaution: Ensure proper terminal spacing and stud / bolt size. CDM Cornell Dubilier • 140 Technology Place • Liberty, SC 29657 • Phone: (864)843-2277 • Fax: (864)843-3800 CDE Cornell Dubilier • 1605 E. Rodney French Blvd. • New Bedford, MA 02744 • Phone: (508)996-8561 • Fax: (508)996-3830 Hardware: M6≈1/4-20 stud / bolt Copper flat washer, M6 washer with 12 mm (0.472") OD Precaution: Ensure proper terminal spacing and stud / bolt size. CDE Cornell Dubilier • 1605 E. Rodney French Blvd. • New Bedford, MA 02744 • Phone: (508)996-8561 • Fax: (508)996-3830
