Datasheet STUSB4500L (STMicroelectronics) - 8
ПроизводительSTMicroelectronics
ОписаниеStandalone USB Type-C sink port controller
Страниц / Страница32 / 8 — STUSB4500L. Pin description. 2.2.15. VREG_2V7. 2.2.16. VDD. DS13102. Rev …
Формат / Размер файлаPDF / 1.8 Мб
STUSB4500L. Pin description. 2.2.15. VREG_2V7. 2.2.16. VDD. DS13102. Rev 2. page 8/32
STUSB4500L Pin description 2.2.15 VREG_2V7 2.2.16 VDD DS13102 Rev 2 page 8/32
34 предложений от 13 поставщиков
STANDALONE USB TYPE-C PORT CONTR. Interface. Interface - Controllers
STUSB4500LQTR
от 39 ₽
STUSB4500LQTR
167 ₽
727GS
STUSB4500LQTR
Hi-Tech Circuit Group
STUSB4500LQTR
This pin is used only for external decoupling of the 2.7 V internal regulator. The recommended decoupling capacitor is: 1 µF typ. (0.5 µF min., 10 µF max.)
2.2.16 VDD
This is the main STUSB4500L power supply. Whatever the application is VBUS powered or not, VDD mandatory connection is to USB power line (VBUS). The STUSB4500L can indeed work in dead battery mode, even for self- powered application, in order to reduce power consumption to ZERO when the port is not attached, therefore having no impact on application power leakage.
DS13102
Rev 2 page 8/32
Document Outline Cover image Product status link / summary Product status link / summary Features Applications Description 1 Functional description 1.1 Block overview 2 Inputs/outputs 2.1 Pinout 2.2 Pin description 2.2.1 CC1 / CC2 2.2.2 CC1DB / CC2DB 2.2.3 RESET 2.2.4 I²C interface pins 2.2.5 DISCH 2.2.6 GND 2.2.7 ATTACH 2.2.8 RP_3A/RP_1A5 2.2.9 GPIO 2.2.10 VBUS_EN_SNK 2.2.11 A_B_SIDE 2.2.12 VBUS_VS_DISCH 2.2.13 VREG_1V2 2.2.14 VSYS 2.2.15 VREG_2V7 2.2.16 VDD 3 Description of the features 3.1 CC interface 3.2 VBUS power path control 3.2.1 VBUS monitoring 3.2.2 VBUS discharge 3.2.3 VBUS power path assertion 3.3 Dead battery mode 3.4 High voltage protections 3.5 Hardware fault management 3.6 Debug accessory mode detection 4 I²C Interface 4.1 Read and write operations 4.2 Timing specifications 5 Start-up configuration 5.1 User-defined parameters 5.2 Default start-up configuration 6 Application 6.1 General information 6.1.1 Power supplies 6.1.2 Connection to MCU or application processor 6.2 Typical application 7 Electrical characteristics 7.1 Absolute maximum ratings 7.2 Operating conditions 7.3 Electrical and timing characteristics 8 Package information 8.1 QFN-24 EP (4x4) package information 8.2 WLCSP (2.6x2.6x0.5) 25 bumps package information 8.3 Thermal information 9 Terms and abbreviations Revision history
