Datasheet ADT7311 (Analog Devices) - 6
ОписаниеAutomotive, ±0.5°C Accurate, 16-Bit Digital SPI Temperature Sensor
Страниц / Страница24 / 6 — ADT7311. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. SCLK 1. …
Формат / Размер файлаPDF / 381 Кб
ADT7311. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. SCLK 1. 8 VDD. DOUT 2. ADT7311 7 GND. DIN 3. TOP VIEW. 6 CT
ADT7311 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS SCLK 1 8 VDD DOUT 2 ADT7311 7 GND DIN 3 TOP VIEW 6 CT
32 предложений от 14 поставщиков
SENSOR DIGITAL -40C-150C 8SOIC. Temperature Sensor Digital, Local -40°C ~ 150°C 16 b 8-SOIC. Temperature Sensors - Analog and Digital Output...
ADT7311WTRZ
150 ₽
Рутоника
ADT7311WTRZ-RL
198 ₽
Зенер
Россия и страны ТС
ADT7311WTRZ-RL
от 229 ₽
Элитан
ADT7311WTRZ
241 ₽
5 00
CS 4 (Not to Scale) 5 INT
0- 05 09 Figure 3. Pin Configuration
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1 SCLK Serial Clock Input. The serial clock is used to clock in and clock out data to and from any register of the ADT7311. 2 DOUT Serial Data Output. Data is clocked out on the SCLK falling edge and is valid on the SCLK rising edge. 3 DIN Serial Data Input. Serial data to be loaded to the part’s control registers is provided on this input. Data is clocked into the registers on the rising edge of SCLK. 4 CS Chip Select Input. The device is selected when this input is low. The device is disabled when this pin is high. 5 INT Overtemperature and Undertemperature Indicator. Logic output. The power-up default setting is as an active low comparator interrupt. Open-drain configuration. A pull-up resistor is required, typically 10 kΩ. 6 CT Critical Overtemperature Indicator. Logic output. Power-up default polarity is active low. Open-drain configuration. A pull-up resistor is required, typically 10 kΩ. 7 GND Analog and Digital Ground. 8 VDD Positive Supply Voltage (2.7 V to 5.5 V). The supply should be decoupled with a 0.1 μF ceramic capacitor to GND. Rev. 0 | Page 6 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS SPI TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER DETAILS TEMPERATURE MEASUREMENT ONE-SHOT MODE 1 SPS MODE CT and INT Operation in One-Shot Mode SHUTDOWN FAULT QUEUE TEMPERATURE DATA FORMAT TEMPERATURE CONVERSION FORMULAS 16-Bit Temperature Data Format 13-Bit Temperature Data Format 10-Bit Temperature Data Format 9-Bit Temperature Data Format REGISTERS STATUS REGISTER CONFIGURATION REGISTER TEMPERATURE VALUE REGISTER ID REGISTER TCRIT SETPOINT REGISTER THYST SETPOINT REGISTER THIGH SETPOINT REGISTER TLOW SETPOINT REGISTER SERIAL PERIPHERAL INTERFACE SPI COMMAND BYTE WRITING DATA READING DATA INTERFACING TO DSPs OR MICROCONTROLLERS SERIAL INTERFACE RESET INT AND CT OUTPUTS UNDERTEMPERATURE AND OVERTEMPERATURE DETECTION Comparator Mode Interrupt Mode APPLICATIONS INFORMATION THERMAL RESPONSE TIME SUPPLY DECOUPLING POWERING FROM A SWITCHING REGULATOR TEMPERATURE MONITORING QUICK GUIDE TO MEASURING TEMPERATURE OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
